For Sell: JL Audio system in a Subthump box
Old Jul 2, 2007 | 11:57 AM
Sluggish's Avatar
Default For Sell: JL Audio system in a Subthump box
For Sell: 3 JL Audio 10W6v2, JL Audio 1800D amp and a custom subthump box(SOLD).
System is 7 months old and was not abused. Im selling it because i rarely listen to it and Im wanting to loose the extra weight off the car.
I will ship or I will meet you within 50 miles of my location. This covers from Houston to Beaumont.
Asking $900+shipping
Edit: Amp picture
Rated Power:
480 W RMS x 1 @ 4 ohm (12.5V);
800 W RMS x 1 @ 2 ohm (12.5V)
THD at Rated Power:
<0.08% @ 4 ohm (20 Hz -25 kHz)
S/N Ratio:
>95 dB referred to rated power (A-weighted, 20 Hz ヨ 20 kHz noise bandwidth)
Frequency Response:
10 Hz ヨ 25 kHz (+0, -1dB)
Damping Factor:
>500 @ 4 ohm / 50 Hz
>250 @ 2 ohm / 50 Hz
Input Range:
200mV ヨ 8V RMS
Dimensions:
15.75" x 9.25" x 2.36"
Features:
High-Damping Class D Circuit with discrete control circuitry (U.S. Patent #6,441,685)
Differential-Balanced Input Topology:
RCA jack inputs (low-level) and multi-pin jack (high-level)
On-board Crossover:
Fully-variable (40-200 Hz), selectable slope Low-Pass (12 or 24 dB / octave)
Preamp Output:
Pass-through type.
Bass EQ :
+6db fixed frequency, fixed 'Q' (defeatable) with port for optional remote bass control (RBC-1).
Dual mono speaker output connections:
accept up to 8 AWG wire
+12V and Ground connections:
accept up to 4 AWG wire
10W6v2
Key Features
* Nominal Diameter: 10 inches (250 mm)
* Continuous Power Handling: 400 Watts
* Dual 4 ohm
* Voice Coil: 2.75" diameter, 4-layer, Kapton former
* Sealed Enclosure Range: 0.50-1.00 cu.ft. (14.0-28.0 liters)
* Ported Enclosure Range: 0.75-1.25 cu.ft. (21.2-35.5 liters)
* VRC Technology
* W-Cone Technology
* Elevated Frame Technology
* Floating Cone Attach Technology
* NeckVent Technology
Specifications
* Free Air Resonance (Fs): 28.5Hz
* Electical"Q" (Qes): 0.497
* Mechanical"Q" (Qms): 8.458
* Total Speaker"Q" (Qts): 0.469
* Equiv. Compliance (Vas): 33.4 litres
* One-Way Linear Excursion (Xmax): 0.60" (15.2 mm)
* Efficiency (1W/1m): 83.7dB SPL
* Mounting Depth: 6.9"
* Mounting Hole: 9.0"
Info from http://www.woofersetc.com/index.cfm?...Product_ID=251
http://www.cartoys.com/Default.cfm/p...DVC_Subwoofer/
Old Jul 2, 2007 | 03:24 PM
Charlie Hustle's Avatar
pics of the amp? specs on the amp?
Old Jul 2, 2007 | 04:35 PM
LawHorn's Avatar
Shut up charlie. How much for the TB
Old Jul 4, 2007 | 06:35 PM
Sluggish's Avatar
Ttt..
Old Jul 4, 2007 | 06:41 PM
volcanic2345's Avatar
if you would how much just for the box and subs! pm me
Old Jul 4, 2007 | 06:46 PM
THE BLACK WIDOW's Avatar
bump for a nice setup!
J
Old Jul 4, 2007 | 07:50 PM
Sluggish's Avatar
PM sent
Old Jul 5, 2007 | 09:01 PM
Sluggish's Avatar
T.t.t
Old Aug 18, 2007 | 06:36 PM
Sluggish's Avatar
T.T.T.......... Reduced price, this stuff is now just sitting in my back room now. Need it gone. I have almost 2 grand in this.
Old Aug 18, 2007 | 11:48 PM
RUSTYTA's Avatar
used to work for cartoys....great price as the amp is worth that alone...bump for a nice system!
Old Aug 19, 2007 | 07:16 PM
Sluggish's Avatar
got bump?
Old Aug 20, 2007 | 08:11 PM
Sluggish's Avatar
Bump-ul-stil-skin
Old Aug 23, 2007 | 04:52 AM
Sluggish's Avatar
I will sell stuff separate.
Old Aug 23, 2007 | 08:58 AM
TheBlurLS1's Avatar
That's what she said...
I've heard this system in person, it rocks, and Ben is a stand up guy.
Old Aug 23, 2007 | 01:58 PM
95stsrider's Avatar
could yo see what shipping would be for the subs and amp to 32258.........i dont really need the box as i will be putting these in my other ride......
Old Aug 23, 2007 | 06:38 PM
Sluggish's Avatar
I'm guessing the weight at 75lbs and it cost 50 bucks for ground shipping.
Thanks Casey
Old Aug 25, 2007 | 04:49 AM
Sluggish's Avatar
Sale pending on the box
Old Aug 26, 2007 | 08:20 PM
Sluggish's Avatar
Bump.... Box is sold. 3 subs and an amp left. New Price 750+shipping
Old Aug 26, 2007 | 11:16 PM
BLACKZ02's Avatar
Thanks again!!
Old Aug 28, 2007 | 06:42 PM
Sluggish's Avatar
200 each for the subs
250 for the amp
or all for 750
