Wiseco custom nitrous pistons, stock '98 LS1 crank & injectors
Old Jul 14, 2007 | 12:28 PM
JimMueller's Avatar
Default Wiseco custom nitrous pistons, stock '98 LS1 crank & injectors
Running low on funds to complete this build and getting rid of this stuff will certainly help. Buyer pays shipping unless local delivery can be arranged.
Qty (1) 1998 LS1 crank w/o reluctor wheel, $100 OBO
Qty (8) Stock 1998 LS1 injectors, GMPN 12554271, Delphi PN 0-280-155-752, 110K miles, $70 OBO
Qty (8) Wiseco pistons, $250 OBO
Includes used pistons & used wrist pins only; used rings & used locks included for free if requested
Bore: 3.905
Dome: 8cc
Rod length previously used: 6.100"
Wrist pin: 2.5" x 0.927", ~ 110g
Piston weight: ~520g (including installed rings)
Ring depths: 3/16, 1/16, 1/16
Compression Height: ~1.30"
Here are the specs as best I can tell. Wiseo doesn't put any markings on their custom pistons, so they have no way of telling what was ordered. The weights were taken from a kitchen scale, not a shipping scale. If you wanted them closer I could weigh them at the USPS.
They are custom Wiseco pistons I bought used in a short block. The original owner said he wanted to build a nitrous motor to take a 300 shot and then changed direction to go with a stroker. The machine shop which ordered the pistons advised that they were ordered custom because there was a lack of shelf pistons with that much dome at the time, and the guy wanted nearly 12:1 compression for the nitrous.
I was told the motor had a 1000 miles on it when I purchased it back in 2004. I suspect I've added about 20K miles to it in that time.
The pistons themselves I have not yet cleaned and there is some minor scuffing on the skirts. I would have reused them, but I did not know how big the dome was until 5 months after I ordered new heads & cam. And my SCR would've been upper 12's with them which is too steep for me on pump gas with my 59cc chamber and .040 gasket. The rings still have good tension but I don't know what they were gapped at, but I think it'd be silly not to re-ring them. I have the Spirolox as well, but I think you're supposed to replace those once removed as well.
Old Jul 15, 2007 | 07:10 PM
JimMueller's Avatar
t t t
Old Jul 17, 2007 | 08:52 PM
JimMueller's Avatar
t t t
