tremec tk0 600 5spd,clutch,ect for ls1
tremec tko 600 5spd,fidanza aluminum flywheel,spec clutch,hydrulic slave cylinder,pro 5.0 shifter,sfi bellhouse,comes with wildwood master cylinder for universal appl. and 05 shifter ****. all with very low hours,just like new. 1500.00 plus shipping or pickup,located in n.w. florida 850 699 2412 please call for any questions
it has different shifter locations so it should line up ok for that,you can call tremec or visit their website also,im sure it will fit with minor mods,use pedals from car same as yours,i dont have any.the master cylinder is a universal unit also that can be fabricated to fit most anything.this trans is STRONG a huge upgrade from a t56.check it out on tremecs website for specs
part # is tcet4168 tremec tko 600 race trans, ratio is 1,2.87 2,1.89 3,1.28 4,1.00 5,.82 this trans is 1975.00 alone,spec clutch,is to 850 ftlbs torque,538.00 bellhouse 479.00 bearing and slave cylinder over 400.00 flywheel,379.00 with ls1 spacer plate for tremec,this is a steal people!!!!!
__________________
"the only replacement for displacement comes in a blue bottle"
__________________
