LQ4 6.0L Long Block (Iron Block Alum Heads)
Complete from valve covers to oil pan. Was pulled from a 2002 Sliverado. This motor is brand new. 317 aluminum heads. With this exception:
A washer was left in the intake and it damamged one piston and slightly damaged the head. Did not affect the combustion chamber just the quench area on one port. The head can be safely milled. The piston should be replaced. So for the cost of a piston and having the heads milled, you will have a brand new 6.0l motor. The motor only fired for a few seconds and was shut off. No metal or debris was circulated through the motor.
$1500 or best offer. Will trade for older sbc/BBC parts.
