Drag Racing Tech
How much abuse can the stock aluminum driveshaft handle?
Old Jul 26, 2007 | 09:01 PM
fastGBcamaro's Avatar
Default How much abuse can the stock aluminum driveshaft handle?
I am planning on going to the track in a couple days and dont have the $ to buy a better driveshaft right now. My setup is in my sig. I should be making just over 500 rwhp. I am going to run a set of 28x11.5 et drags. So does my stock shaft stand a chance at all?
Old Jul 26, 2007 | 09:44 PM
gator's 99TA's Avatar
i have seen them go as quick as 1.39 60 on a t56 car locally. it broke the next pass.
Old Jul 27, 2007 | 12:40 AM
TwoFast4Lv's Avatar
I am hitting mine with over 700Ft TQ out of the hole. It will go one of these days I AM sure
Old Jul 27, 2007 | 06:36 AM
tektrans's Avatar
Mine went and cracked the trans housing (not the tailshaft) in the process.
Old Jul 27, 2007 | 10:11 AM
badpewter-z's Avatar
LS1TECH Sponsor
it could hold for a bit but defiently make sure you have a loop just in case
Old Jul 27, 2007 | 12:02 PM
El_Diablo's Avatar
Not worth the trouble man. A better driveshaft is good insurance.
Old Jul 27, 2007 | 02:22 PM
Default thanks
Thanks for the replys. I will probably try to borrow a friends steel ds, since his car is down right now anyway.
Old Jul 27, 2007 | 02:26 PM
5301113's Avatar
+1 .
daniel6718's Avatar
1.49 60' no problem over and over and over
Old Jul 28, 2007 | 11:57 AM
Ego Killer's Avatar
I have been many 1.45s on mine and hasent broke YET.
Old Jul 28, 2007 | 12:31 PM
Wicked ls 1's Avatar
1.41/1.45 consistently and its held up for 2 yrs, In a a4 though. M6 id definetly get a steel ds. But run a loop regardless good insurance if it does go.
Old Jul 28, 2007 | 06:00 PM
James Montigny's Avatar
I've seen those suckers twist and beat the hell out of a tunnel and I pipe.
At a minimum you want a safety loop, you should also look at a beefier shaft.
I went with a CM shaft just in case
Old Jul 28, 2007 | 08:39 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
Keep in mind, the old LT1/1LE shafts are much stronger than the LS1 style.
I've seen quite a few 315 drag radial cars with under 450rwhp & M6 destroy the LS1 type.
Old Jul 29, 2007 | 06:55 AM
JL ws-6's Avatar
Race your car!
IMO, I wouldn't trust it.
A big aftermarket alum one would be fine, or you can get a steel one if you don't mind the weight. fwiw I have a 3.5 inch alum one.
Old Jul 29, 2007 | 07:34 PM
ls14jay's Avatar
Mine twisted off with drag radials on a moderate launch.I wouldn't trust it, especially without a loop.
Refer to picture in sig
Jay
Old Jul 31, 2007 | 11:39 AM
wolfy's Avatar
i broke mine when i only had a lid and cutout on street tires. and people here say this is the worst prepped track they've ever seen...
then again, ive seen them go 1.40 60's, and 10's...i think its alot like the stock 10-bolt; it's eventually gonna break on you, but for now, it'll either break or it won't...
Old Jul 31, 2007 | 01:25 PM
5_02ls1's Avatar
my 98 doesnt have the aluminum shaft ....what year did they stert using it...mine is steel
Old Jul 31, 2007 | 05:33 PM
Default only year
Im pretty sure the 98's were the only year LS1 that came with the steel ds.
Old Jul 31, 2007 | 06:14 PM
JL ws-6's Avatar
Race your car!
I don't even think all of them came with the steel shaft.
Old Aug 1, 2007 | 02:57 PM
n2ojunkie's Avatar
twisted mine in half with under 500 rwhp on et streets. I was leaveing at 5k rpm on a very sticky track, but the car never moved, just twisted the ds and ripped the tq arm off the rear. I bought a stock steal one and put new u joints in and have been beating the hell out of it sense.
I think the v6's and the v8 cars with the speed limiter at 110mph got the steel ones. Dont quote me thou.
