CNC ported heads,2002 WS6 wheel, TBs ported & stock,Goodyear F1 tires,BBC 454 engine
Old Aug 14, 2007 | 05:37 PM
floman's Avatar
Default CNC ported heads,2002 WS6 wheel, TBs ported & stock,Goodyear F1 tires,BBC 454 engine
I have several parts for sale, links to pics are below each items description. I will accept Paypal with the fees added, or postal money orders. Whoever pays first gets the parts,and buyer pays for shipping fees. Parts are located in Orange,Tx about 100 miles east of Houston. Will add pics shortly.If you dont like the prices PM me with offers
1) CNC ported 853s 2.02"/1.57" stainless valves & LS2/LS6 springs. Heads are off of a 2000 DRM ( Doug Rippie Motorsports ) C500/RSR Corvette package car. 500hp/500Tq 382ci built car.http://www.dougrippie.com/drm/drmc500rsr.htm , these heads flow 282.2cfm @.550" intake, and 199.5cfm @ .600" exhaust without a flow pipe. Craig Gallant @ GTP Racing in Houston,Tx flowed them for me, and I do have the flow sheet. These would make a great budget head for someone running a mild 220 to 230 duration cam. Heads have been milled .006" just to clean the surface. Looking for $700.00, I will post pics of them assembled in a day or two.Consider trades for Prostars 15x3.5"s & 15x8"s or 15x10"s w/correct offsets,or OEM SS hood, or ?
Flow sheet #s, exhaust flowed without a pipe
Lift Int Exh
.100" 66.9 51.0
.150" 100.3 76.6
.200" 134.3 102.1
.250" 165.0 120.5
.300" 195.6 138.9
.350" 220.8 154.7
.400" 245.8 170.5
.450" 266.5 181.5
.500" 281.7 188.5
.550" 282.2 194.9
.600" 280.4 199.5
http://s3.photobucket.com/albums/y55...Cported001.jpg
http://s3.photobucket.com/albums/y55...Cported002.jpg
Added new pics to show more detail
http://s3.photobucket.com/albums/y55...ads853s017.jpg
http://s3.photobucket.com/albums/y55...ads853s016.jpg
http://s3.photobucket.com/albums/y55...ads853s015.jpg
http://s3.photobucket.com/albums/y55...ads853s007.jpg
http://s3.photobucket.com/albums/y55...ads853s006.jpg
http://s3.photobucket.com/albums/y55...ads853s005.jpg
http://s3.photobucket.com/albums/y55...ads853s003.jpg
http://s3.photobucket.com/albums/y55...ads853s002.jpg
2) 2002 WS6 polished 17x9" wheel, very slight bend on lip that does not affect seal, holds air fine, $100.00-SOLD! to "buck6680" - Thanks Cliff
http://s3.photobucket.com/albums/y55...eeltire001.jpg
http://s3.photobucket.com/albums/y55...eeltire002.jpg
3) Ported 98-99 TB, has been painted black, $35.00
http://s3.photobucket.com/albums/y55...FORSALE019.jpg
http://s3.photobucket.com/albums/y55...FORSALE020.jpg
4) Ported 98-99 TB, no sensors, , $60.00-SOLD!
http://s3.photobucket.com/albums/y55...FORSALE015.jpg
http://s3.photobucket.com/albums/y55...FORSALE014.jpg
5) Stock 2000-2002 or 2004 GTO Ls1 TB, no sensors, 20K miles, $50.00SOLD!
http://s3.photobucket.com/albums/y55...TOLS1TB001.jpg
http://s3.photobucket.com/albums/y55...TOLS1TB002.jpg
6) Pair (2) Goodyear F1-GS 275-40-17s, practically new 85-90% tread remaining. $375.00 pair
http://s3.photobucket.com/albums/y55...eeltire003.jpg
http://s3.photobucket.com/albums/y55...forsale005.jpg
7) Big Block Chevy 454
I built this engine for my 90 454SS , but wound up selling the truck before I made the swap. The engine still needs a oil pump, oil pan, and harmonic balancer and of course accessories. Engine has not been fired and is fresh. Should make decent power and lots of torque and make a great street motor. I am in Orange,Tx 77630 roughly 100 miles east of Houston on the TX-LA border. If you have any questions feel free to PM me here, e-mail to fhuff1@yahoo.com, or call me at 409-882-9889.
Big Block Chevy 454- 4 bolt main block Bored .030, Keith Black Hypereutectic .030 flat top pistons,approx 9.0-9.25 comp ratio, truck rods, moly rings, cast crankshaft is std-std on mains & rods, Federal Mogul bearings, complete Comp Cams camshaft kit w/ cam, lifters, springs, retainers,locks, pushrods, Magnum roller tip rocker arms, and double roller timing set. Heads are 1971 820 castings large oval ports w/ semi-open chamber 113cc combustion chambers, have been milled .020" & worked in the valve bowls with stock size valves, and have been gasket matched and lightly ported in the Int, & Exh. runners but nothing radical just good smoothing and cleaning. Heads are bolted down with ARP head bolts.
Camshaft specs are Grind # X4-270H Extreme Energy Hydraulic values are @ .050 lift Dur 226* int 234* exh, lift ,544" int .564" exh, 1600-5800 rpm .
range.
Intake manifold is GM oval port dual plane hi-rise, carb is Holley 850cfm vacuum secondary specifically metered for GM 454 & 502 H.O. crate motors. Valve covers are GM 502 H.O. finned aluminum. Headers are Hedmann Elite Series coated 1 3/4" long tube for 1990-1993 454SS trucks.
Engine needs oil pump, oil pan, and harmonic balancer.
Price- $2500.00 as is
$2250.00 minus headers
$2000.00 minus headers & carb
http://s3.photobucket.com/albums/y55...leparts037.jpg
http://s3.photobucket.com/albums/y55...leparts036.jpg
http://s3.photobucket.com/albums/y55...leparts035.jpg
http://s3.photobucket.com/albums/y55...leparts034.jpg
http://s3.photobucket.com/albums/y55...leparts033.jpg
Old Aug 15, 2007 | 08:34 PM
floman's Avatar
Flow sheet #s and more pics added. Will consider some trades on the heads. Looking for some light weight wheels, prefer Prostars or maybe Draglites. Might consider a OEM SS hood, or?
Old Aug 16, 2007 | 12:37 AM
1_badz28's Avatar
pm sent
Old Aug 16, 2007 | 12:25 PM
floman's Avatar
Originally Posted by 1_badz28
pm sent
"1_badz28" - I returned your PM to you. Let me know if you need more info.
Floyd
Old Aug 16, 2007 | 09:04 PM
floman's Avatar
All PMs have been returned. Up for Thursday evening.
"Zger"- I sent you a quote for the shipping on the Big Block Chevy engine.
Old Aug 17, 2007 | 11:59 PM
floman's Avatar
Up for Friday night. Updated the list.
Old Aug 19, 2007 | 02:47 PM
floman's Avatar
Up for Sunday afternoon.
Old Aug 20, 2007 | 04:49 PM
floman's Avatar
Up for Monday afternoon. I'm open to trades on some of this stuff.
Old Aug 20, 2007 | 05:09 PM
JTelesone's Avatar
ttt. damn thats a good deal on those heads.... I would pick them up if it was the end of the month already. You posted them up ten days early!!!!
Old Aug 20, 2007 | 08:53 PM
floman's Avatar
Keep them in mind. You never know, I might still have them then. Just let me know if you get serious towards the end of the month.
Floyd
Old Aug 21, 2007 | 09:00 PM
floman's Avatar
Up for Tuesday evening.
I added some new pics of the DRM CNC ported heads. Shows a little more detail and pics of them assembled and ready to bolt on. Surely somebody needs some budget heads and with 853 castings nobody will suspect a thing!
Old Aug 22, 2007 | 11:12 PM
floman's Avatar
All PMs have been returned. Up for Wednesday night.
Old Aug 23, 2007 | 11:19 PM
floman's Avatar
Up for the Thursday night crew.
Old Aug 24, 2007 | 12:32 AM
m1candelaa1's Avatar
Would the heads work with my set up? I have a magic stick 3 cam,thanks
Old Aug 24, 2007 | 11:33 AM
floman's Avatar
Checking on that for you, we will see what the guru's know.
Old Aug 24, 2007 | 11:41 PM
floman's Avatar
Old Aug 26, 2007 | 10:31 PM
floman's Avatar
Up for Sunday night.
Old Aug 30, 2007 | 08:28 AM
floman's Avatar
Up for Thursday morning.
Old Aug 30, 2007 | 06:24 PM
floman's Avatar
2002 WS6 wheel- SOLD! to "buck6680" - Thanks Cliff
Old Aug 31, 2007 | 12:36 AM
CharlieSS's Avatar
Get back at me today about the engine. Lets work something out man.
