moser/strange 9" w/WOLFE anit-roll bar, 7.350" pushrods...
***EDIT FOR PICS***
i am putting up my 9" for sale. i realize now i went a little overkill.
IT IS COMPLETE, READY TO BOLT IN!
moser housing, 35 spline axles (moser stickers on the ends & protective film still on them), 1/2 x 3" studs, strange aluminum case, billet pinion support, billet yoke, strange light weight steel spool, motive 3.89 gears. i added a drain plug to it also. it has the WOLFE RACECRAFT anti-roll bar installed, LCA relocating brackets welded on, MADMAN shock brackets welded on (afco style modified to work with my QA1's, so they will work with either).
it has about 3k miles on it, new axle bearings & seals. NO traction/abs, my car is a 3 channel but it didn't affect me.
it has my 3 channel backing plates on it, IF you send me your backing plates i will knock some $$$ OFF!
I'm looking for $2300 + shipping, or i will deliver/meet within a couple hundred miles.
Originally Posted by 94 guy
what are you going to put in the car?
probably with a iron 3rd member, 4.11 gears, 31 spline axles (gun drilled & star flanged), tru track, stock sway bar.
