driveshaft loop problem, help!
Old Aug 31, 2007 | 09:00 PM
LS1NUT26's Avatar
Default driveshaft loop problem, help!
I just bought the Jegster driveshaft loop for the F-bods and it only looks like I can use 2 of the 4 bolts if you look at this pic you can tell that it is not as wide as the Lakewood or the SLP. Have you guys got any input?http://www.jegs.com/webapp/wcs/store...57228_-1_10061
Old Aug 31, 2007 | 09:20 PM
2 fast 2000's Avatar
That's right! You should be using 4 total. 2 on one side and two on the other. My BMR only uses 4 total, so you should be good.
Old Aug 31, 2007 | 09:37 PM
LS1NUT26's Avatar
What do you mean?
I can only get 2 bolts in not 4
the bracket on the loop don't seem wide enough.
Should I scrap this thing and get a Lakewood , or what does anyone think?
I called Jegs tech support on this and they seem as sharp and a butter knife.
USELESS
By looking at the link, does it look like it will only fit a 82-92 or what?
Old Sep 1, 2007 | 12:08 AM
LS1BADZ's Avatar
82, 93, 02.....all the same
Old Sep 4, 2007 | 09:23 PM
LS1NUT26's Avatar
well if they are all the same, how come it won't line up right?
Like I said, by looking at the jegster one vs. the lakewood one the spacing between
the two bolt holes on both sides are about an inch and a half off.
any feedback on this?
Old Sep 4, 2007 | 11:01 PM
I would return it!
All the bolts should line up fairly easy!
Old Sep 5, 2007 | 10:44 PM
LS1BADZ's Avatar
I guess the jegster one sucks? lol
I looked and Lakewood sells one for 82-92 and 93-02...
I can get you the lakewood one for $50.99 plus tax...that's $1 cheaper than Jegs
plus you don't have to pay they're shipping and handling or whatever!
Old Sep 7, 2007 | 07:50 PM
LS1NUT26's Avatar
Got a PM from someone selling an SLP D/L for $50.00
might go with that.
Old Sep 7, 2007 | 09:10 PM
camaroguy26's Avatar
um that says 1982-2002. I might be wrong but I think the body changed in 1993? Not sure if 98-02 is even the same as 93-97? anyways I think you're right, those bolt holes don't look as far apart as it needs to be. Don't know what the SLP is like but I bought the lakewood for my 98 Z28 and I love it. It fits really tight to the tunnel, and it goes up and over the exhaust instead of down under, so I know it's not going to make me lose ground clearance. My UMI brace dragged a lot and at stock height! the only grudge against the lakewood is that the driveshaft weight is freakishly close to the loop, but I have a few thousand miles on it and no problems yet, not even little taps against each other
