Resonable turbo kit
Old Sep 9, 2007 | 07:12 PM
black98ws6ta's Avatar
Default Reasonable turbo kit
I have a Qmp/TTi street kit style turbo kit for sale. I bought it off of a car that was wrecked in the rear. I am not 100% sure about the specifics on the turbo but I am going to make some calls and figure it out tommorrow. The turbo kit is in good shape overall and everything works properly. Heres a list of parts:
-76mm turbonetics on center turbo....(has a billet backing plate, water ports, and a restrictor on the inlet I believe it is dual ball bearing....will update asap)
-hks standard wastegate
http://www.hksusa.com/products/?id=807&rsku=4645
-hks standard bov....recirculating type that exits back into the intake tract for the turbo, helps with respool on a 6 speed
http://www.hksusa.com/products/?id=761
-all intercooler piping is stainless material, top section to intercooler is silicone, connects at turbo and intercooler are reinforced hose type
-intercooler is a medium size but efficient, goes in with little modification and bumper removal isnt needed
-Kit uses a stock passenger exhaust manifold, crossover pipe is for a automatic transmission 2.25'' diameter that enters the back of the drivers log manifold via 2 bolt flanges. The car has a 3'' downpipe that is one peice all the way back to the axle and has a bullet muffler inline. Over the axle is one single tip that extends to the bumper. If shipped I will make 1-2 clean cuts in the downpipe to ship so they can be rewelded on the car or expanded and made slip fit. Everything on the turbo kit is stainless steel except for the stock passenger exhaust manifold.
- The kit installs very easily and can be done in a full day to someone that has experience.
- Does not require a aftermarket k member, has perfect ground clearance.
-The alternator relocation bracket that comes with the kit uses a stock length belt.
- Kit comes with powersteering lines that are longer so you can route them away from heat.
- Kit will come with new k and n replacement filter
- Kit will be sold 100% complete with everything you need to install
- Kit comes with spacers for the front sway bar
- Kit keeps a/c and stock fans and radiator in stock location for stock cooling
I have personally seen this kit make 800rwhp on a dynojet, through a 6 speed, on a 347 engine. Several people have been low 10's and high 9's using it, but I believe that is pushing the kit beyond its limits. I do believe you can put this on a completely stock motor and it will spool great, make enough power(500rwhp+) to hurt a stock motor and be completely reliable. I wouldnt reccomend pushing it above 600rwhp on a built engine.
I am asking $3700 o.b.o. shipped/$4000 shipped with a set of used 60 lb motron injectors, I will post pics later tonight. I will be cleaning the kit up alot, these pics are fresh after removal.
Some pics of it right after removal.
Old Sep 10, 2007 | 09:38 PM
To the top!
Old Sep 11, 2007 | 12:22 AM
frcefed98's Avatar
looks like a big crack on the passenger side crossover to cast manifold flanges...right at the weld.
Did you already get that fixed or is it something the buyer has to take care of?
Old Sep 11, 2007 | 11:31 AM
I forget to mention that, it was already repaired.
Old Sep 11, 2007 | 12:35 PM
RealQuick's Avatar
Good ******* eyes Jer!!
Nice kit!
Old Sep 13, 2007 | 10:56 PM
top the top
Old Sep 15, 2007 | 03:20 PM
60 lb injectors were sold seperately, and the price is OR BEST OFFER
Old Sep 16, 2007 | 09:34 PM
pm's and emails responded to
Old Sep 18, 2007 | 12:12 PM
$3500 shipped, and I have told several people I will modify the crossover to fit a 6 speed transmisson if somebody 6 speed buys the kit.
Old Sep 18, 2007 | 10:14 PM
top the top
Old Sep 23, 2007 | 01:28 PM
Sale is pending. Thanks
