FS: Strano Sway Bars 35mm/22mm
Old Sep 13, 2007 | 02:37 AM
Tropi-Care Jason's Avatar
Default FS: Strano Sway Bars 35mm/22mm
I have a 22mm rear sway bar, and the 35mm front sway bar. There is about 2000 miles on them. They were bought from another LS1tech member and have sat around in my garage. The rear bar is in perfect shape, but the front is just SLIGHTLY bent on the right side from the accident the previous owner had. When I went to put them on the right side was just slightly bent in. It's so slight you can't tell at all until you go to hook up the end link. So it might be possible to heat it or something to bend it back out to where it should be.
rear bar only - $150 shipped
front and rear - $250 shipped
includes bushings and end links.
Thanks!
Old Sep 13, 2007 | 10:16 AM
2000KnightRider's Avatar
I might be interested in these. Let me check my source to see if he can torch out a bend like that.
Old Sep 13, 2007 | 12:06 PM
PMs replied to!
Old Sep 13, 2007 | 06:08 PM
Sold!!!
