LT1, SBC performance parts
I have a bunch of stuff to get rid of. Some parts are new some are not, I will specify in the description. All are in perfect working order. I except paypal or money order. I will eat the paypal fee on all my items. Shipping is noted within each item. I have an excellent history so buy with confidence.
Items can be seen at : Items for sale
Ford 9" aluminum daytona pinion support. Used, for up to 33 spline. $75 shipped
MSD Digital 6 plus. Used, a few scratches and a small cut in the back of the case I did with the cut off wheel, surface only, in perfect working condition, I left a lot of the leads when I took it out so it's easy to hook up. $155 shipped
MSD HVC II coil. New, never installed, part # 8253 $90 shipped
MSD window switch. Used, comes with 3800 and 6800 pills. $50 shipped
Mark Williams billet 26 spline trans yoke for T56. New, switched to viper trans and never used it. $100 shipped
95 LT1 PCM. PCMforless tune. 396, ported heads, 254/260 .680, 110 lsa, 36lb injectors, M6 all the other goodies. $100 shipped
94 LT1 PCM original Ed Wright PCM retuned by Shalin Patel for 355, stock heads 230/236 .510 110lsa, 42lb injectors, M6 P600B 15lb boost. Tuned for boost so you don't have to use an FMU. $100 shipped
Spohn torque arm mount. Used, has mount off the middle for dual exhaust. Structurally sound, scuffed pretty good on the bottom but still a good piece. Has driveshaft loop and is dipped for mufflex exhaust. SOLD
JAZ Breather tank. Used, -10 fitting $40 shipped
JAZ 45* filler neck for fuel cell. New $40 Shipped
Flaming River steering joint. New, FR1716DD 3/4" DD each end. $30 shipped
Autometer ultralite Water Temp Gauge. Used 2 1/16" $25 shipped
Moroso U-joint girdles #85810 for 12 bolt with 1310. New. $15 shipped
Moroso V-belt vacuum pump pulley. Used $25 shipped
MSD APS Alternator bolt on pulley. New, Serpentine, GM. $18 shipped
Factory 24 lb injectors. Used, 35,000 miles. $35 shipped
Factory M6 consol insert with lighted rocker switch. Used. SOLD
Please pm me or drop me an email. I will provide a phone # if you need to talk about something. All itmes are as advertised, I don't sell junk. Thanks for looking.
Dave
Dave
