99+ Fuel Module and 42# SVO Greentops
Old Sep 21, 2007 | 05:15 PM
BlkHwk's Avatar
Default 99+ Fuel Module and 42# SVO Greentops
Like the title says 42# SVO Greentop Inj. and Fuel Module for 99+ F body modified for Walbro pump with pump installed. Roughly 3K to 3.5K miles on both. Pump holds good pressure and does not leak. Have tested it out of car and it doesn't leak. After key is cycled and pump stops running holds 40psi pressure. Will throw in a short piece of steel braided hose if desired.
$250 plus shipping on inj. and 140 shipped on pump. Pump does not have fuel level sender. You would have to reuse the sender from your unit.
Old Sep 21, 2007 | 06:19 PM
DarkDemon's Avatar
250 shipped on injectors?
Old Sep 21, 2007 | 06:50 PM
BlkHwk's Avatar
Works for me.
Sending PM
Old Sep 21, 2007 | 07:18 PM
BlkHwk's Avatar
Injectors SOLD
Old Sep 22, 2007 | 07:46 AM
BlkHwk's Avatar
Bump For The Pump
Old Sep 25, 2007 | 06:43 PM
BlkHwk's Avatar
Bump for Low Mileage Fuel Pump
Old Sep 29, 2007 | 07:52 AM
BlkHwk's Avatar
up up up
