NEW Procharger F1a w/front mount intercooler
I have forsale a brand new procharger F1A headunit along with all the necessary Parts to install and run the kit, minus the crank pulley and tensioner. The Intercooler and piping have been used for approximately 1500 miles. The j-bracket has been test fitted only, as well as the hardware being used on a different f1a kit previously. As you can see everything shines like new and looks killer especially installed. It has a custom intake instead of the plastic intake plenum. This flows thousand fold better. It is a 4" intake with a Huge K&N airfilter. It is using a blowoff valve which is a Tial 50mm (purple anodized). On a 408 stroker with afr heads and this exact setup (different HeadUnit though, still an f1a) put down 850hp to the wheels on 15psi. That was without the sdce tensioner kit (not included and I don't have one) which I highly recommend you buy as you will experience belt slip under a lot of boost. The pulley that is on the head unit now is a 8 rib 4.75 pulley. The Sdce kit is around 600 dollars and they modify the j-bracket with a new tensioner as well as give you the new pulleys you need. The intercooler is good to well over 1k hp. I am throwing in an electric fan for you to run on this kit that is a thinner profile then stock. If you end up needing another one I will direct you to where I've found the best bang for the buck on fans. I've decided to go a different route, that is the only reason for selling. Plastic is on all the openings as you can see in the pics to keep dust and dirt out, as i live in a new development area and it's really dirty!
What you are getting-
New F1A Headunit Rated at 1100hp
4.75" head unit pulley
2 bottles of procharger oil.
New J-bracket
All necessary hardware to bolt on and go, minus crank pulley and tensioner
Tial 50 mm Blow off valve
One electric fan
All but 1 or 2 of the necessary t-bolt clamps
Custom Intake setup with K&N airfilter
Front Mount intercooler with Polished end tanks good to over 1k hp
All polished aluminum piping for the front mount
Piping rubber couplers
May be something I am forgetting, check pics
You will need a complete fuel system for this unless you plan to run it on your stock engine, then I'd just get the bigger injectors, and a plug and play racetronix fuel pump kit. I highly recommend getting a wideband air fuel meter and you definitely need someone to tune this unless you can handle that your self.
The kit is sold as is, where is. I will ship at your expense.
Price WITHOUT shipping is 4k obo. Paypal is excepted, but you will pay those charges unless we have some sort of an agreement. Let me know of any questions or concerns you have through PM's. Thanks, Dan
EDIT: Trades are considered. Let me know what you have. Performance oriented only!!!
Pics!!!- http://s143.photobucket.com/albums/r...TA/Procharger/
New J-bracket
One electric fan
i am interested you have everything to install on my 98 ta right if you do mail me at roysideways@yahoo.com with your number an we will see if we can set this up
Possibly pending tomorrow. Payment is supposed to be sent VIA Certified Check Tomorrow overnight. I'll keep you all updated on here. Still pm me if interested just in case it falls through. Dan
