FS: Welds, comp, carrier, trans cooler, trans parts
-Selling my 15x10 weld draglites with MT ET streets mounted on them. One slick is 30-40% gone, and the other is past the lines so Im guess is over 75% gone. I had to replace one tire a while back due to a staple. The wheels have not been screwed. I have also 10 lugs with washers Ill be throwing in. No center caps. One wheel/tire want hold air longer then a couple weeks (The new tire) Ive noticed that once I take them off after a couple weeks one always leaks down. Also had this problem with my telstars. Ive taken the wheel and tire to be looked at but found nothing wrong. Once I got them and started grinding on the calipers I was test fitting them after each grinding session so they have some rub marks in them. Asking $450 plus shipping or I can meet within a resonable distance. Im loacted in Central Bama and work downtown Bham mon-fri. If anyone is intrested in just the wheels I can let them go for $350 SOLD!!!!
- Comp 7.2 PR's. Brand new never used. Ended up with wrong length. $75 shipped.
- 2 series 10 bolt 4 channel carrier. Removed with 14,xxx miles. Also has the center block with 8mm bolt included. Excellent condition, great replacement for a broken stocker. $110 shipped
- 20,000 GVW trans cooler with all mounting hardware. Brand new in the box. Was going to replace mine but never made it around to it so Im letting it go. $35 shipped.
SOLD!!!!
- Factory 4l60e. Ran it in my car for a couple months while I gatherd parts for 4l80e swap. Slips a bit in 4th I think. I cant remember what gear it was, defiantly wouldnt hurt to rebuild, but it works and shift fine now. $100 plus shipping or can pick up. SOLD!!!
- Factory 4l60e trans brace $10 plus shipping
-Factory 4l60e dipstick tube, has a tiny hole in the very bottom that would need jb welded. $5 plus shipping.
- Factory 4l60e converter 60,xxx mi. $20 plus shipping.
SOLD!!!!
Ill pm you some pics now...
Thats cool but I want be making the shootout. I cant say Ill hold it. Ive actually got another member from TN coming down that claims he wants it.
