243 Heads, 3.42 Gears, Torsen T2, MAF, D/S Window Motor, Rear Axle Bearings + more..
Old Dec 1, 2007 | 05:01 AM
BklynZ28's Avatar
Default 243 Heads, 3.42 Gears, Torsen T2, 2 85mm MAFs, D/S Window Motor, Rear Axle Bearings.
243 Heads
Heads were pulled from an 06 Trailblazer 5.3L LH6 w/ 32k.
Engine had lower end noise, engine was replaced.
Heads sustained no damage.
Stock Springs w/ green stripes, Non Sodium Valves.
SOLD
GM 3.42 Gears
New in Box, Zero Miles.
GM PN 12471191, GM Parts Direct = $ 513.94.
$250 Shipped
GM Torsen T2 3 Series Carrier
GM PN 12471371, GM Parts Direct = $ 473.20
SOLD
GM / AC Delco 3.5" / 85 mm MAF
New In Box.
Upgrade for 94-97 LT1, 98-02 LS1.
5 wire connector & PCM programming required to convert.
GM PN 15904068, GM Parts Direct = $ 121.65
I have two of these MAFs, Both Brand New.
$80 Shipped
GM / AC Delco Window Motor + Regulator, Drivers Side
New, Still in Package.
GM PN 10305686, GM Parts Direct $113.34.
SOLD
Looking to sell the items below complete for $100 Shipped
Added up worth over $200.
4 Bottles GM Synthetic Axle Lubricant, 75W-90, 32 FL OZ
2 GM Differential Cover Gaskets
GM Timken - Rear Axle Wheel Bearings.
GM Timken - Pinion Bearing, Larger one.
GM Timken - Carrier Bearings.
GM Axle Tube Seals.
100 % positive feedback on EBAY : User ID : MOhara6012
Additional Pictures found here : Link
Paypal Email : MOhara6012@aol.com
Thanks for Looking!
BklynZ28
Old Dec 1, 2007 | 08:14 AM
ecetim's Avatar
Unfortunately I can't take advantage of any of your great deals, but just wanted to say thanks for having detailed descriptions, clear communication, and good pictures. It makes a world of difference in my opinion, compared to the slackers on here who can barely manage a coherent sentence much less a proper FS thread.
Good luck
Old Dec 1, 2007 | 08:15 AM
floman's Avatar
Very interested in the heads. How would you want to do payment? Could you send some more pics of the heads to me at fhuff1@yahoo.com, show the valve sides and ports.
Floyd
Old Dec 2, 2007 | 10:07 AM
usd2sing's Avatar
interested in the window motor/track assbly.
unclear on part number tho.
part number is for a TB correct?
Old Dec 2, 2007 | 10:33 PM
hirdlej's Avatar
PM Sent on heads
Old Dec 2, 2007 | 11:01 PM
BklynZ28's Avatar
Hey,
Thanks for the compliment, ecetim.
Yea.. Took a little while to make the post and take pics.. I agree, having a
clear post avoids confusion.
To usd2sing,
The Window Motor & Regulator is still for sale.
The Part Number for the Window Motor & Regulator listed above, 10305686,
seems to work at GMpartsdirect.com.
The Heads are currently pending sale.
Thanks all,
Mike
Old Dec 5, 2007 | 11:30 AM
BklynZ28's Avatar
Bump..
Old Dec 5, 2007 | 11:58 AM
mesospeedy's Avatar
I already have a 85mm maf almost identical to the one you have, minus the screen. My car has been tuned with it, but at WOT im getting a code so I think I might need to replace it. I have the 5-3 wire adaptor already, would I need to be retuned seeing as I already have a delphi 85mm on the car?
Old Dec 5, 2007 | 12:31 PM
hirdlej's Avatar
Did the heads ever sell?
Old Dec 5, 2007 | 02:09 PM
Tobynine9's Avatar
Is the rear a T2 or a T2R? If it's a T2R, I'd buy it.
I looked but couldn't find any info to check the T2R part number against the regular T2 number to see which yours is.
Old Dec 5, 2007 | 02:13 PM
snketr's Avatar
I'll take the MAF. Do you take paypal?
Are you sure that's the 85mm MAF? I looked on GMPD and that MAF is for an LS1. The LS6 MAF is PN#25341604
Old Dec 7, 2007 | 07:56 AM
BklynZ28's Avatar
Hello,
mesospeedy - I would first check that you are in fact getting a MAF code,
before replacing the MAF and possibly having the same problem.
hirdlej - The heads have been sold.
Tobynine9 - I'm pretty sure it a a T-2 and not the T-2R.
snketr - MAF is still available. New in Box. $80 shipped.
Thanks all,
Mike
Old Dec 11, 2007 | 09:02 PM
BklynZ28's Avatar
bump...
