non-LSX Parts For Sale SBC, LT1, V6, etc.
Garage clean out, needs to go
Old Dec 18, 2007 | 12:42 PM
FASTFATBOY's Avatar
Default Garage clean out, needs to go PARTS ADDED 2-4-08
PM'S OK
Speedadikk@aol.com
Shipping not included from Mobile Ala
Lt1 factory roller lifters, came out of a running 383, nice shape $75
LT1 COrvette oil pan $100
Lt1 oil pump drive(under the intake) $10
LT1 alternator brace $10
LT1 factory oil fill cap $5
Grey T Top SHades, NICE shape $80
Grey sunvisors, good shape the little deal on the sides flops around.$25
Hooker 4 inch to 3 inch reducer $5 NEW
1 set of Corbeau seat sliders $15(4 TWO FOR EACH SIDE) Sliders only
Grant kit to mount a Grant 5 bolt steering wheel to a 93-2002 F BODY, was put in car and taken out to install a disconnect, with horn button $15 SOLD
Factory Black Camaro steering wheel with airbag, from a 94 Z, Very good shape $40
Mass air flow meter, no screen, Mallory Billet Aluminum MAF ends, Ends are brand new, MAF is used... $50, the ends alone were $80 SOLD
4 gallons of Evans cooling $65
1 roll of 3/8 aluminum tubing, 10 feet I think..never used $10SOLD
2 K&N push in valvecover breathers $10 each SOLD
LT1 washer bottle with pump $10
Trans converter dust shield(auto) $10 SOLD
LT1 Accessory bracket, top two holes have been enlarged(just use washers) $10 SOLD
Black 4 inch 45* rubber hose coupler NEW $20
Thermo Tec starter heat shield kit, NEW $10
LT1 rear main seal adapter $10
LT1 Belt tensioner $10 SOLD
Lifter valley spider $10
LT1 F body Factory motor mounts $20 SOLD
1994 Opti harness $20
Global West rear spring height adjusters with matching springs, fit in factory location, Adjust ride height in the rear $125.
GM factory service manual for 1996 F Body, book 1 of two, Driveability and emissions, trans diagnosis, electrical diagnosis $20
Milodon oil pump primer tool, part#23000 $25
Erson vacuum reservoir can, black $20
Set of LS1 head gaskets, Fel Pro part number 9284 pt$30
SHipping will be from Mobile Ala
David
Old Dec 31, 2007 | 07:18 PM
FASTFATBOY's Avatar
Up Top
Old Jan 3, 2008 | 02:09 PM
Speed Density's Avatar
hashtagBMW
Bump..
Tony.
Old Jan 7, 2008 | 06:37 PM
FASTFATBOY's Avatar
TTT Parts added
D
Old Jan 8, 2008 | 10:10 AM
chevalierss's Avatar
have pics for the oil pump drive assembly? I'm interested if the teeth are in good shape.
Old Jan 15, 2008 | 10:36 AM
FASTFATBOY's Avatar
Up Top
Old Jan 23, 2008 | 08:59 AM
FASTFATBOY's Avatar
To da top
Old Feb 4, 2008 | 11:52 AM
FASTFATBOY's Avatar
Monday crew
Old Feb 9, 2008 | 12:21 PM
94blownz281's Avatar
i will give you $50.00 for the lifters shipped
Old Feb 9, 2008 | 10:02 PM
sweet-94z28's Avatar
Could you send pics of the grey sunvisors to mickelsonn@hicksvilleschools.org
