C5 Corvette Single Turbo Setup and Tons of Other Brand New Parts from the Turbo Build
1) I have the brand new HSC single turbo kit. Included within the kit is
2)AEM Wideband is up for grabs next. A necessary part to any FI build. Measures your Air/Fuel ratio, which allows you to tune your car and make sure it is running perfect. 52mm gauge. $240 plus shipping
3)Comp Stock Length 5/16 Hardened Pushrods. Part number 7638-16. $90 plus shipping
4) A set of 317 casting GM heads with around 3000 miles on them and upgrade Patriot Gold Dual Valvesprings. Heads come fully assembled with the Patriots and the stock valves. $400 plus shipping.
Pictures can be found here
I believe that is all for right now. Now for the reason I am selling all this stuff. It is because the vette was a project between me and my dad, but like somethings in life it just wasn't ment to be. So we are getting rid of all the aftermarket stuff along with the car also. Anyone in the Southern Wisconsin/Northern Illinois area is welcome to stop by and check this stuff out for yourself. Like I said everything is brand new except for the heads.
If you have any questions i will do my best to help you out and make everything as smooth as possible.
Thanks Josh
- Turbonetics T76 with a .96 AR and S-Trim Wheel
- Custom Passenger Side Turbo Manifold
- 3" Downpipe
- Air to Water Intercooler setup that fits nicely within the front bumper
- Turbonetics Racegate Wastegate
- Turbonetics Raptor Blow-off valve
- All the necessary hoses and fittings to bolt this into your C5
Thanks Josh
