5.3 in a 1993 jeep yj
Old 12-21-2007, 12:15 PM
lsxyj's Avatar
Default 5.3 in a 1993 jeep yj
well i have started have most of the parts i need
5.3
4l60e
howell harness and computer
dana 300 in a stack case
speedway caoted block hugger headers
corvette oil pan gona try it hope it will work
auto meter guages new bezels on the way
gona make my own mounts
Old 12-21-2007, 03:28 PM
98blackSS's Avatar
Nice.. Take lots of pics. I may start my swap as soon as this weekend. Depends whether our local club wants to go wheeling this weekend or not If not then I'll be starting the 4.0 pull on Monday.
I'm also using the 5.3, 4l60e, autometer gauges.. I'm using AA for the mounts, TC adapter, radiator, misc mounts.. I'll have to look into those block hugger headers as I don't have that part covered yet.
Old 12-21-2007, 04:45 PM
V8TJ's Avatar
5.3
4l60e
Excellent. x2 on the pics!
98blackSS - GO wheeling then start the swap!!!
Old 12-21-2007, 11:10 PM
ryanvv355's Avatar
This is gonna be sick
Old 12-25-2007, 06:47 PM
lsxyj's Avatar
well the speedway headers r not gona work they would be good for really tight fits but i have more room than that they exit right into the block and oil pan too close.
here is the empty bay
in close to where it is going to be i want it back a little more and maybe up some
looks like the stock manifolds from the pickup will work for now
Old 12-25-2007, 08:27 PM
98blackSS's Avatar
Good info.. I'm supposed to start my teardown tomorrow. Which model are the headers exactly? They exit into the block?? weird..
Were they the tight fit or clipsters?
Old 12-25-2007, 08:30 PM
Boodyrider's Avatar
Nice. Years back a buddy and I dropped a 302 Boss into a CJ5, made for a Jeep that'd smoke 12.5 wide tires in all gears, all ranges!
Old 12-25-2007, 09:40 PM
lsxyj's Avatar
they were the tight fit also they dont leave much room for motor mounts
Old 12-27-2007, 06:08 PM
lsxyj's Avatar
the ac compressor is going to work fine in stock 5.3 position
also the corvette oil pan is going to work with the removal of about two inches of the driverside wing to clear the front driveshaft
Old 12-27-2007, 06:16 PM
98blackSS's Avatar
Wow, how'd you pull that off? Almost every install I've seen requires hacking up the frame rail on that side to clear the compressor. Looks like you have loads of room. I was planning on leaving mine off because of this. Maybe I'll have to slap it back on now.
Old 12-27-2007, 06:20 PM
lsxyj's Avatar
ya looks like everthing is going to work well even gona have plenty of room to fab the motor mounts hope to get to them next week also trying for a flat belly pan that may work out also ;}
Old 12-28-2007, 04:26 AM
venomhp's Avatar
I helped a buddy of mine do this in his YJ, if you have any questions PM me, looks great so far!
Old 12-28-2007, 01:20 PM
LS1TECH Sponsor
Schwanke Engines's Avatar
Let me know if the engine feels sluggish down low. I may have a fix for it.
Old 01-01-2008, 02:14 PM
Area 51 Racing's Avatar
Yea I'm getting ready for my swap shortly too. Except mine is a little different.. I have a 88 yj body on a 1980 toyota frame and axles... and now i'm putting a mild Lq4 in it, its very unique.. take lots of pics of your build
Old 01-01-2008, 05:21 PM
V8TJ's Avatar
Info!
Old 01-01-2008, 05:43 PM
lsxyj's Avatar
heres the engine mounts the trans crossmeber is next then i will pull it all out and finesh welding the mounts clen and paint them
Old 01-02-2008, 08:16 AM
LS1TECH Sponsor
Originally Posted by V8TJ
Info!
What do you need info on?
Old 01-06-2008, 04:14 AM
lsxyj's Avatar
it is looking like the 5.3 is gona be replaced with a 6.0 will know for shure ina few days
Old 01-28-2008, 10:44 PM
ryanvv355's Avatar
Is there a 6.0 in it or what? I know where theres one that will probably sit in a garage forever.
Old 02-05-2008, 06:16 PM
lsxyj's Avatar
the 6.0 fell thru so gona be a 5.3 hope to put it back in for the final time by the ned of the week
Quick Reply: 5.3 in a 1993 jeep yj
