LOTS OF 93-02 PARTS [updated 12/22]
I would like to have this posted in both the lsx and non lsx since many of the parts apply to both years. Please see this link for pictures of the parts:
https://ls1tech.com/forums/showthrea...121&highlight=
Pictures are at the bottom of the page. If you are interested in something that does not have a picture, then contact me and I can try to get you a picture. If there is not a price after the part then make an offer. I don't have set prices in mind for everything. Will be updated when I have time.
-93-02 Passenger Side Air Bag $45 obo
-98-02 Firebird/Trans Am headlight trim covers. SOLD
-93-02 Firebird/ Trans Am, 97-02 Z28 HVAC Controls. $15
-93-96 Z28 Fuse Panel Cover $10
-93-97 Trans Am/Z28 K&N Air Filter. Used for less than 100 miles. Retail $40 plus shipping. Asking $30 shipped.
-AC Delco Oxygen Sensor. 30K miles. Worked perfecctly when removed. Should fit front or rear in 98-02 fbodies or rear of 93-97. It is the square 4 pin plug.
-Another 4 pin oxygen sensor. Bosch. 5k miles. Like New.
-93-02 Fbody Clutch Master Cyliner U bolt. $5SOLD
-93-97 LT1 AC Compressor. 55k miles. Worked perfectly when removed. Tape in the picture is on there to keep trash out of the compressor since the lines are not hooked up.
-94 Firebird/Formula/Trans Am owners Manual w/ warantee books. $10 SOLD
-97-02 Fbody Change holder that goes in the coenter console. $5
-93-02 Trans Am Fog light switch. $5
-93-97 LT1 Air Foil. Comes with everything pictured. $10 shipped SOLD
-93-02 Low Coolant Switch. Worked perfect when removed. $5
-93-97 LT1 Coolant Temp. Sender. 10k miles. $5
-LS1 Coolant Temp Sender. 5k miles. $5
-93-02 Dark Grey/Charcole Seat Belt holder that attaches to seat. Driver side. $15 obo
-LT1 Knock Sensor. 10k miles.
-LT1 Cam Retainer Plate. $10
-Stock LT1 Cam. I have 3. $20 obo 1 sold, 2 left
-Stock LS1 Cam. 30k miles.
-93-97 Fbody AC Condensor. No leaks. $25 obo
-93-02 Fbody Hood Latch, Bumper Support, Latch mount.GM stickers on them still. SOLD, still have the other used one
-93-94 LT1 Exhaust Manifold. Will also fit on 95-97 if you have a 93-94 y pipe. 40k miles. $35 obo
-93-97 Fbody Parking Brake Cables. $25 obo per pair
-93-02 Fbody coolant overflow/battery mount. Front battery mount not broke off or cracked. $25
-98-02 LS1 AC Evaperator. $15
-93-97 Cruise Control Box. sold
-93-02 Fbody Tail Light Harness $15 sold
-93-02 Fbody Steering Collumn. I should have the key to it. $40 obo
-93-02 Fbody Jack/Lug wrench $15
-93-97 LT1 AC Line. Runs to compressor, condensor, firewall. Tape over ends in pic is to keep trash out of the line. $40 obo
-93-97 LT1 EGR Tube. Alum. tube that runs around bottom of the engine. Rare to find these not cut up. $20 obo
-93-97 Trans Am Front Turn Signal Black out covers. $10 sold
-93-02 T-top holder / Bar. Runs front to back in the middle of the t-tops. Dirty in pic. I did not have time to wash it off. $15
-93-97 LT1 4L60E Transmission Shifter Cable and bracket that mounts to the transmission. $20
-93-02 Trans Am Passenger Window/Lock Switch. Switches work good. Not broken
-93-02 Fbody Auto Pedal Assembly $35 obo SOLD
-93-97 LT1 Upper Coolant Hose. 5k miles.
-93-02 Trans Am fuel door w/ hinge $20 obo
-93-02 Z28 fuel door w/ hinge $20 obo
-93-02 Fbody Auto Shiffter Assembly. $25 obo
-98-02 Fbody Master Cylinder and ABS Block. 30k miles. sold...only one master cyl. left now
-93-97 Fbody ABS Block
Fbody Interior:-Sail Panels. Both Tan and Grey/Charcole
-Rear Hatch panels w/ speakers. Tan and Grey/Charcole
Non Fbody Specific:
-Viper 300 ESP Alarm w/ 1 remote. make offer
-Single gauge pod. Attaches to your a pillar with push pins. 2 1/16" gauge.
Other Fbody Parts From Last thread that are still left:
-Custom brake booster. Based in house of kolor black and then sprayed with red miniflake. 3 coats of clear on top of that. I was going to run it on my show car but ended up going with manual brakes. $50 obo. I have more then that in the paint on it.It does has some dust on it in the picture. It looks great when the sun hits it!
-One off HVAC box modifed to only run heat and no ac. All AC parts and ac core were removed from the box to save weight. Box was cut and redesigned to give a better appearance in the engine bay and give you more room. I can take some pictures of it if you would like. Based in black and then it has a satin flat automotive clear over it to give it a chassis black look. make an offer.
-10 bolt Gears: 1 set of 3.23s and 2 sets of 2.73s. All in great condition with low miles. $30 for the 2.73s and $50obo for the 3.23s
-Hood latch cable. fits 93-02. $10
-98-02 Trans Am passenger headlight cover. Slight bend on the tip but easily fixable. make offer(pic below)
-93-02 trans am rear marker lights for bumper. make offer
-93-97 LT1 valve springs, retainers, locks, and lifters. all have 35k miles on them. make offer on what you want.
-LT1 water pump cam drive splined shaft. make offer
-Key & lock combo's. Includes both door lock cylinders, rear hatch lock cylinder and matching key. make offer.
-93-02 Formula hatches. I have numerous colors. make offer and pm me if you need a certain color.
-93-02 camaro hatches. I have numerous colors. make offer and pm me if you need a certain color.
-93-02 Z28 manual crank window doors. Green in color. Includes doors,handles,locks, and all crank mechanisms inside. NO interior panels. $120 for the pair obo
I have the following parts available off a 96 Z28:
All prices are w/o shipping
-Headlight support bar with all the lights and adjustors(pic below). make offer.COLOR=red]SOLD[/COLOR]
-Rear filler panel that says "CAMARO".(Fits 93-02) $40 oboCOLOR=red]SOLD[/COLOR]
-Rear quarter panels in perfect condition.(Fits 93-02) make offer sold
-Pass and Driver doors in great shape. power windows. complete with everything but the interior panels.(Fits 93-02) $65 per door obo
-Driver side fender in great condition. make an offer
-A4 trans cross member $15(pic below)
-Gauge surround trim $25
-Fuse cover SOLD
-Front bumper orange light. $8 (pic below)
-Automatic console insert (pic below) $15
-Pair of Z28 exhaust tips.SOLD
-Grey complete seat belt set.Includes every seat belt and latch out of the car.(Fits 93-02) $65 obo
-Manual lock slide buttons. These are the pieces you slide to manually lock your doors. They normally get broken when removing the door panels. These are in great shape.(pic below) $5 for the pair
-Complete set of BOSE speakers. I have the door speakers, sail panel speakers, rear sub, and amp. Make an offer on what you need.(Fits 93-02)
-Air bag panel for the dash. This is the panel out of the dash that covers the air bag. Great condition. $50 obo
-Stock LCAs, panhard, torque arm, spindles,brakes,upper and lower from a arms, k member, pwr steering rack. make an offer
-Stock front and rear brake rotors. make offer
-parking brake handle and assembly $15
I have the following off of a 01 Z28:
-Air box lid. pic below. make offer
-Passenger side headlight.SOLD
-Optional OEM side ground effects. Come complete with all the mounting tabs that rivet to the body to hold the skirts on so you do not have to use two sided tape. Great condition.(Fits 93-02) make an offer.Sides SOLD, bumper with rear ground effect still for sale
-Optional OEM rear ground effect riveted to the bumper as it comes from the factory. Bumper and ground effect will be sold together since they are attached with rivets from the factory. Paint is in great condition.(Fits 93-02) make an offer.
-Stock muffler.(Fits 93-02) $25
-Front Core support.(Fits 93-02) I'll cut it off completely so you can drill out the spot welds wherever you would like. $70
-Z28 Steering collumn w/o wheel. comes with key.(Fits 93-02) $30
-Stock torque converter. 20k miles on it. make offer
-Stock LCAs, panhard, torque arm, upper and lower from a arms, k member,pwr steering rack. make an offer
-Front brake hard lines that run from the abs block over to the caliper hoses. These are the lines that run along the frame/k member
Non Fbody Specific:
-Fuse cover SOLD
pm me a price on the headlight panel with the lights and stuff with adjusters from the 96 Camaro..Im in desperate need of one and would love to take this off your hands..email some pics as well badmaro34@hotmail.com
Interested in the 93-97 LT1 EGR Tube what would shipping cost to 01603 in addition to the $20.00? a few small misc items that weren't on your list that I'm also looking for are screws for the interior console, Door panel screws, Plastic interior door lock covers, 97-02 console compartment.
Take it easy
Brewski
Take it easy
Brewski
