383 +stock rotating assembly, Lt1 LS1 lid kit, Optis, 58mm, 36#hr, leather seats, etc
Hugeeeeeee sale! Going carbed and forced induction so I have A LOT of NA and fuel injected parts I need to sell. This will be funding the current build, which I'm trying to finish for the LTX Shootout. So, buy now and help a brother out!
Stock Lt1 rotating assembly that I replaced with the 383 rotating assembly.
$250 shipped [heavy]
Stock Lt1 springs, upper retainers, and locks.
$35 shipped
Lt1 starter
$40 shipped
Power steering pump (I have 2 of these)
$35 shipped each
AC Delco Opti with MSD cap n' rotor off a spare Lt1 I sold.
$150 shipped
Opti harness
$15 shipped
Vacuum harness.
$10 shipped each
95 ICM and coil. Coil was new from autozone this summer, has ~4k on it. Comes with spacers and longer bolts for the "cooling mod"
$35 shipped
95 ICM
$15 shipped
$35 shipped
Lt1 starter
$40 shipped
$35 shipped each
$150 shipped
Opti harness
$15 shipped
Vacuum harness.
$10 shipped each
$35 shipped
95 ICM
$15 shipped
OBDI knock sensor. Verified working with datamaster.
$10 shipped
Knock sensor off a OBDII car that threw no codes.
$10 shipped
Good shape Lt1 injector pigtails
$15 shipped
A4 trany xmember
$25 shipped
6 speed lower shift boot
$20 shipped
LS1 intake kit, made to fit LT1 cars with a WS6 or cowl hood. Will not fit stock hoods.
Stock LS1 ws6 ramair lower airbox modified to sit much lower than it did stock. Clear MTI lid. Newer Fram airfilter. Couplers needed to atatch from Lid to MAF, then MAF to LT1 throttle body. MAF to throttle body coupler has hole for IAT and opti harness line.
Here's the catch. You will need to dremel a small portion of your hood if you have a WS6 hood. The front corners of the lid ever so slightly hit the hood. You can put grease or marking compound on the corners and slowly let the hood down on it. Pick the hood back up and mark the hood where the grease stuck to it from hitting the lid. Dremel slightly into the hood untill it dosen't hit. The hood is 2 layers, if you go through do not worry there's another 1/4 or more inches till the outside skin of the hood. You cannot see the dremeled areas from standing around the car. You can only see them if you lean over top of the engine bay and look striaght up (who does that?). The other catch is the one bolt hole is broken but the airbox is PLENTY secure with 3 bolts. You will need 2 drill 2 holes and get 2 self taping screws as the LS1 airbox holes are in diferant spots than the LT1 core support. Herle is a picture showing where I dremeld. I got went quite overboard and never smoothed it out. You could take less off and do a better job. There's 2 eye level pics showing you cannot see the marks standing by the car. $200 shipped
Leather seat set. The drivers side seat is hammered. You can see the 2 big tears in it. Passenger seat is mint, there is one small line of discolord leather you can see in the pic, nothing bad at all. The rear seats are mint as well minus the closeup pic I took. it looks to be a very small smudge of gray paint. It would probably come out.
$300 picked up. I will ship them for an additional $180.
Seatbelt set, good shape. Comes with all the hardware.
$50 shipped
Another seatbelt set in good shape. I'm not certain if this one has all the hardware.
$45 shipped
1995 Passenger airbag
$40 shipped
silver radio bezel
$10 shipped
93-96 console lid in good shape
$15 shipped
All prices OBO!
hey, what's up man. it's steve with the pewter z28 here in hermitage. i thought you just put that thing together last year? figured you'd go bigger since ya couldn't hang with the ls1 at sunset? haha, j/k man.
i might be able to use some of this stuff. i'll send a pm.
Sorry the holidays have been hectic, I got your stuff shipped out and I have the tracking number at home. I will PM it to you this evening. Yes, if it doesn't clear could you please do an instant transfer, I wouldn't even ask but ebay just charged my seller fees automatically and my paypal is in negative balance. Stupid Ebay pissing me off more, double checked and automatic payment is OFF.
