12 Bolt, T400, Lots More
ok, Weve still got some stuff off of bills car. it sa 1997 trans am ws6. please pm me if you want something on the list.
i also have some ls1 stuff and some ls1 truck stuff.
all price are OBO and i will try to meet you within a resonable drive. thanks larry
headlight switch assembly 10.00
150 mph gauge cluster. it reads 70-72K 75.00
simpson harness 35.00
headlight covers 25.00
pushrod guide plates(stepped) 30.00
ARP header bolts 3/8 by 1 12pt p/n 400-1209 25.00
ARP rocker studs p/n 234-7202 50.00
both t-tops. 50.00 each
rear bumper cover 75.00 WS6 emblem still on there sale pending
12 bolt rear end. STRANGE, wolfe sway bar 4:10's and spool Have all new hardware to mount the sway bar to
the car.1750.00
more infoon rear. 33 Spline Axles, Lightweight Spool with 4.10 PRO Gear, Wolfe Racecraft Anti-roll/Sway Bar welded on, relocation brackets welded on, has 1/2 Wheel Studs, Gear has very low runs.
PCM with LT1 Edit (Will be getting the edit box soon)
- Cam (Joe O. cam) 236/244 on a 109 LS, install at 105 $200
needs opti pin (new)
Door, t-top weather seals. 20.00
oil pressure sender gm p/n 10201491 $30.00
- Simpson Harness Y TYPE. FOR FLOOR MOUNT. 35.00
A pillar plastic 25.00
head liner 40.00
LS1 SLP ORP. this are the little pipes that go where the cats are for track use. 25.00
TCI Flexplate for LT1OR SBC - TCI (SFI) Flexplate 399173 (NIB) SOLD
reman power steering rack 75.00
oil pan gskt LT1 p/n 10108676 30.00
door hinges 15.00
Turbo 400, with shift kit, reverse valve body, trans brake, hughes tranny cooler pan. this is the tranny I had in my car, I got it off evil. 700.00
99-02 silverado carbon fiber hood and hood pins. 100.00 I got this off of BADMOFO. it was a good fit. and very light. but i want a cowl hood for my truck.
like i said pm me or email me at larry01z28@hotmail.com or carrielb@cvn69.navy.mil
im willing to meet you if you want some of the bigger items. and if you want more then one thing we can work out a deal. thanks larry
the car.1750.00
head liner 40.00
door hinges 15.00
pm me your meail addy and ill send you soem pics. i really dont know how to post pics up here. ill shoot the pics to you tomrrow. as far as miles. i would say around 1500 to 2000 miles. gears look brand new.
