trans am parts!!!
All parts are from a silver 98 trans am with only 34k miles on it
please pm me if your intrested in anything. and of course these prices do not includes shipping and pick up only on the larger items.
t-tops, great shape set $250
flowmaster 80 series including over the axle with clamp and factory aluminum tips $100
t-tops sunshades $50
nice driver door pewter color $150
nice silver passanger door with mirror $150
rear brakes includes rotors, calipers, rubber lines and brackets $150
eibach sportline lowering springs $150
complete hatch with spoiler and tinted glass $200
factory gm amp $25
factory sway bar front $50
rear sway bar $30
both airbags $200
k@n filter $20
spare tire package $75
aluminum driveshaft $125
owners manual $30
rear-view mirror $30
left front fender $100
radiator aluminum $100
A/C condensor $50
side skirts $75 each
gas tank and pump assembly $100
also have
misc. wiring harnesses, interior trim, abs motor fuse boxes and plenty other parts still left feel free to ask and ill be glad to look for you. thanks!
factory gm amp $25
rear sway bar $30
both airbags $200
k@n filter $20
owners manual $30
A/C condensor $50
also have
it does have good sail panels but i dont know if they are for monsoon or not. didnt know they were different. let me know what to look for and ill see if there the ones you need. the springs are sportlines they drop it more than the pro-kit. thanks
I need the front door tweeters if you have them, they mount on the plastic door panel. ill take the wiring coming off the door too if you can 2" is fine. let me know. I also need the lock down pins for the rear 1/4 panel over spare tire plastic . The little pins that lock/unlock and foam. Center rear tail light filler is red? faded at all? if not Let me know what you want!
