Race Heads, Tranny Coolers, Many Parts, look inside! Everything you need!
Old Jan 21, 2008 | 12:21 AM
roadracetransam's Avatar
Lightbulb Race Heads, Tranny Coolers, Many Parts, look inside! Everything you need!
Shipping is not included in prices, buyer pays actual shipping cost. My Zip is 92336. E-mail questions /paypal to scottsz100@yahoo.com.
Price/description below pictures:
Happy shopping....
Ignition Switch $10
Hood Props $10
Door Locks with key $10
Lifter Trays $20
Electric Trunk Release $20
Hood Hinges $20
Stock LS1 valve springs $30
Stock Panhard rod $30
LS1 Rear Cover $30
LS1 Lifter Valley Cover $30
Window Control Module $30
30mm Front Sway Bar $30
19mm Rear Sway Bar $30
Stock Balancer $35
Master Cylinder. $35
Brake Booster. $35
Stock Cam $35
Wiper Motor with rod assembely, wiper arms $40
Flowmaster 2 chamber muffler $40
Body Control Module BCM of '98 Trans Am. $40
CD player Radio from '98 Camaro $40
WestCoast Racing Cylinder Heads. CNC Ported LS1 heads. .045 milled. 2.02/1.57 stainless steel valves, Comp cams dual springs 158 seat pressure, 393 open pressure, 1.750 installed height, 1.060 coil bind. (My cam had 615+ lift.) Combustion camber volume 60 cc. Flow ratings with a .600" lift: 293 cfm intake, 223 cfm exhaust
Over $1300 invested. For sale $680 for the pair.
ATM-2601 Auto Meter Z-Series Analog Gauges
Gauge, Z-Series, Boost/ Vacuum, 30 in. Hg/ 20 psi., 2 1/ 16 in., Analog, Mechanical
AutoMeter boost gauge. $25
NEW! CCA-774-16 COMP Cams Steel Valve Spring Retainers
Valve Spring Retainers, Steel, 7 Degree, 1.055 in. Outside Diameter, .640 in. Inside Diameter, Set of 16 $25
Heavy Duty Momentary Toggle switch (for starter as example) $15 PENDING
Aluminium tranny cooler 11"X15". $50
NEW! 10 bolt fel-pro cover gasket $5
'98-'02 T/A headlights. $20
T-tops with keys, tinted $130 for both or will separate @ $65 each.
Oil filter relocator for dual filters. $30
Stock Amplifier. $15
Air Pump. $10
Transmission / oil cooler 11"X18" $75 PENDING
Pedals from '98 Auto Brake + Throttle $20 Pending
Clutch Master Cylinder. $50 SOLD
http://memimage.cardomain.net/member...90_30_full.jpg
K&N Filter $19 SOLD
http://memimage.cardomain.net/member...90_64_full.jpg
12 bolt, rebuild kit includes everything $75 SOLD
http://memimage.cardomain.net/member...90_60_full.jpg
TFS-21407300 Trick Flow Chromemoly Pushrods
Pushrods, Chromemoly, Heat-Treated, 5/ 16 in. Diameter, 7.300 in. Length, Universal, Set of 16 $75 SOLD
http://memimage.cardomain.net/member...90_42_full.jpg
'98-'02 side windows $50 for both. Will separate @ $25 for each. SOLD
Old Jan 21, 2008 | 12:32 AM
3fingas's Avatar
pm sent on the heads
Old Jan 21, 2008 | 12:51 PM
I did not recive a PM. Please try me again.
Old Jan 21, 2008 | 05:28 PM
Originally Posted by duketxboy
Is That A After Market Tranny Cooler Pm Me Thanks
PM-ed you.
Old Jan 21, 2008 | 05:49 PM
nbm00ss's Avatar
what kind of power did those heads make?
Old Jan 21, 2008 | 10:24 PM
450 hp 470 tq
Old Jan 22, 2008 | 05:52 AM
nbm00ss's Avatar
what supporting mods. very interested in them and would just like to know what to expect
Old Jan 22, 2008 | 01:42 PM
240+ duration, .600+ lift, 106 separation cam, LS6 intake, wide open exaust, thin gaskets, tuning ect...
Old Jan 23, 2008 | 12:34 PM
To the top
Old Jan 23, 2008 | 11:18 PM
BlackDevil's Avatar
BAD SELLER
https://ls1tech.com/forums/itrader_d...=40511&u=62470
Old Jan 23, 2008 | 11:58 PM
Originally Posted by BlackDevil
I have sent this guy his parts within 12 hours of reciveing payment. USPS has not delivered it. I kept in constant communication with him, sent every paperwork to him, sent him tracking numbers, he even has my cell number. I called USPS 5 times, went down to the Post office 3 times. They have sent the parts out. There is not much more I could have done.
Old Jan 24, 2008 | 04:52 PM
to the top
Old Jan 24, 2008 | 07:02 PM
72Elkytpi's Avatar
interested in the oil filter relocation part. Please pm me the lowest shipped price to florida.
thanks
Rich
Old Jan 24, 2008 | 07:43 PM
YORK_MUSTAINE's Avatar
Also Interesrted In Oil Filter Relocation, Fits To Lt1?AND THE LS1 AIR FILTER
Old Jan 24, 2008 | 11:34 PM
Should fit the LT1's too. Sent you a PM.
Old Jan 25, 2008 | 10:33 AM
strasser_3's Avatar
what would the heads need to be installed
Old Jan 25, 2008 | 11:20 PM
A set of head gaskets, pushrods and head bolts.
Old Jan 26, 2008 | 01:19 PM
to the top
Old Jan 27, 2008 | 08:40 PM
to the top
Old Jan 29, 2008 | 02:07 PM
To the top
