4l60E Upgrades....help/suggestions needed.
Old Feb 14, 2008 | 10:38 PM
TravisA's Avatar
Default 4l60E Upgrades....help/suggestions needed.
I'm getting ready to install an edge 4000-4200 stall in my LT1('94 4l60e) and was looking for ways to help the tranny live. Keep in mind this car will be shifted around 6700-6800 and the car has put down 420+ with the stock conveter in it.
Also some fyi on the transmission condition...The car was purchased from a friend and he had the tranny rebuilt about 10k ago, fluid is clean and doesn't smell burnt. I'm assuming it was just a stock rebuild on the transmission.
Right now I'm collecting parts, so far I've just purchased a Tru-cool 4490 cooler and was thinking of adding a modified trans-go hd2 shift kit. Would this help? Also with the rpm I'm shifting at would it be smart to add a high output pump slide spring? As long as I can get it to live through the summer/fall I'll be happy. After that time I'm going to send it off to one of the sponsors on here for a rebuild.
Any other suggestions on what to do? Am I on the right track? All suggestions,tips,tricks and any info/help is greatly appreciated!
Thanks!
Travis
Old Feb 14, 2008 | 10:41 PM
Gilbert@Ace Racing's Avatar
All of those upgrades sound fine.
At the end of the day though unless you do not replace the piston return springs inside the unit the high rpm's are gonna do it in... especially if it has the original "helper" springs at the 3/4 clutches.
But those mods ought to help it live in the short term.
g
Old Feb 16, 2008 | 05:41 PM
TravisA's Avatar
g
Thanks for the reply.
Isn't the helper springs included in the transgo kit? Also isn't that the springs it says to leave out in the atsg book?
Thanks again!
Old Feb 16, 2008 | 08:04 PM
The springs I am referring to are located under the snap ring in the 3/4 clutch pack itself. Yep, these are the ones referenced in the ATSG book.
Depending on which kit you use you will indeed find they supply "stiffer" piston return springs.
Good Luck with it.
g
Old Feb 17, 2008 | 12:23 AM
'00SLVRDO's Avatar
5-pinion front and rear planets out of a 4l65e, 9-clutch 3-4 pack: alto red eagle clutches/kolene steels, trans-go shift kit, steel separator plate, and hi-rev spring kit. "The Beast" sunshell, kevlar band, 29-element sprag. I think that's most of the upgrades to look into to get the most out of a 60.
Old Feb 17, 2008 | 12:29 AM
performabuilt's Avatar
LS1Tech Sponsor
Sounds good
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Feb 17, 2008 | 01:05 AM
I do not agree with the Alto clutches. IMHO (and many other builders) they are inferier to a woven clutch like Borg Warner High Energy clutches.
Aside form that, there are several proprietary modifications I would perform. But, those stay close.
g
Old Feb 17, 2008 | 02:04 AM
FLT's Avatar
FLT
I do not agree with the Alto clutches. IMHO (and many other builders) they are inferior to a woven clutch like Borg Warner High Energy clutches.
g
I hope you don't mind me seconding this motion. I know how much it pisses you off when people copy what you say. At the end of the day a clutch is just what it is. If the hydraulic's don't work.....I don't care what you put in front of oil pressure. Meaning the build is just as good as it is set up. Plain and simple. Vince
