PRC 5.3 vs PRC LS6 heads
Old 02-26-2008, 12:06 AM
Midnight02's Avatar
Default PRC 5.3 vs PRC LS6 heads
Just finished reading a bunch of good information thanks to the search feature, however (given that I'm working on getting a better understanding of how a head swap will help me make more power) I thought I should post this to see if I could get some more precise feedback.
Here's the situation: See mods below. I have all of the goodies and it's time for a head swap. I would like for my car to have reliable street manners and good power under the curve. A good power goal would be around 430 rwhp (I'm currently making 390 rwhp and 388 rwtq). Ultimately I'd like to find a set of heads to compliment my cam and other mods. My only future plans are to throw on a 100 - 125 shot of N20 and a 9" rear end.
I've done a good bit of research and I'm very comfortable with the quality and price of the ported PRC heads, however I can't seem to decide between the Stage 2.5 5.3L heads and the Stage 2.5 LS6 heads. It looks like the LS6 heads have marginally better flow numbers, while the 5.3 would significantly increase the compression of the motor, thus making good top end power (as well as plenty of torque down low). Given my criteria, which of these two would you recommend for my setup? Should I have TSP mill the heads too?
Sorry for asking a bunch of questions, however I'm (slowly) learning all of this. Thanks!
Old 02-26-2008, 12:19 AM
96lt1ss's Avatar
Id choose the 5.3s for compression advantages.
Old 02-26-2008, 12:46 AM
jshelton2006's Avatar
i've been wondering the exact same thing with my MS4...i'm glad you started this thread!!!
Old 02-26-2008, 01:14 AM
98RedBird's Avatar
Go with the PRC 5.3 2.5's... The added compression will be much more beneficial. And have TSP mill the heads to 59cc and go with a Cometic .040" gasket. The motor will love the added compression and when you go nitrous in the future it will love the extra compression even more!
Just make sure to check your PTV
Old 02-26-2008, 01:50 AM
Gun5's Avatar
can't he just mill the LS6 and get the best of both worlds? better flow and higher compression
Old 02-26-2008, 02:07 AM
stevied916's Avatar
he could. the ls6 is better suited for large cams or more cubes though because of the larger runners. The 5.3's smaller ones will help keep some midrange torque for a street car. Dont forget about tea too..
Old 02-26-2008, 02:15 AM
Gun5's Avatar
ya I want some heads up TEA vs PRC.... well there is many guys with the cam I want todo (228/232) and LS6 heads pulling 430-440+
Old 02-26-2008, 04:04 AM
00MaroonZ28's Avatar
Same here too. I'm debating whether I should go with the 5.3 or LS6 heads with my Trak cam. Starting to lean towards a 59cc LS6 Stage II for higher compression ratio and better flow. Anyone have any ideas for this setup?
Old 02-26-2008, 08:15 AM
TXZ28LS1's Avatar
seen good results with both. but i always thought the LS6 always outflowed 5.3 heads? but i would go with LS6 heads!!
Old 02-26-2008, 09:29 PM
Gun5's Avatar
want to see more on this topic
Old 02-26-2008, 09:39 PM
99mongooSS's Avatar
If your going to use the MS4 cam, use the LS6 heads. If using the MS3 or smaller cam use the 5.3's
Old 02-26-2008, 10:05 PM
ScreaminBird99's Avatar
i am going with the cosmetiic gaskets however my 5.3 heads arent milled, am i losing much power?
Old 02-26-2008, 10:21 PM
Midnight02's Avatar
Thanks guys...great feedback so far. It looks like both the 5.3 heads and the LS6 heads are tried and true and put down solid numbers. Based on the flow numbers, the Stage 2.5 LS6 heads flow slightly better than the Stage 2.5 5.3 heads. Given that I'm looking to increase compression (hence building low to mid range torque), it sounds like I would be best suited with the 5.3 heads. The 5.3s should also nicely compliment my relatively mild cam.
I think where I'm getting confused is when you throw "milling" into the mix. By milling the heads, it helps increase compression even more, hence increasing the velocity of movement of air through the heads (please correct me if I'm wrong on this). Can you guys give me a simple explanation as to how this is accomplished?
I apologize for all of the questions. I'm completely dumb to a lot of this stuff, however I'm learning more and more each day.
Old 02-26-2008, 10:27 PM
cdoggy81's Avatar
I would go with the 59cc LS6 & here is why...
For a long time I WOULD HAVE voted for the 5.3 heads on a street car. Mainly for what all you read about with their smaller runners & higher compression making more torque & power "under the curve". This is true to a degree. Now since then I have had some LONG talks with major head porters. The keys are runner design, runner volume, flow, velocity, & how they all work together. With stock cubes, you don't want to just start hogging out the intake and exhaust runners because the velocity will probably slow down even though you'll have great flow numbers! Typically with the bigger runners you lose some velocity which will affect your bottom end and part-throttle response. There seems to be a fine line of flow vs. velocity & good porters know this. Runner shape and the cross section of the port is more important (to a certain point) than just runner volume. A well designed smaller runner can flow better than a larger runner. Now all that being said, volume alone does not always dictate velocity. As long as the cross section is not too big, and has the proper shape, you won't lose velocity... Lets look at LS1 heads, LS6 heads & aftermarket heads.
LS1 head ~ 205cc runner & flows ~ 230cfm
LS6 head ~ 215cc runner & flows ~ 260cfm
A.M head ~ 205cc runner & flows ~300cfm
LS6 head has larger runners & flows more than a LS1 head. OK, based on the above info you prob. think it gives up a lot of velocity & low end b/c of the hogged out runners. Not the case... I makes MORE power b/c it is a better "design" & still keeps the velocity up. How can the aftermarket heads have a smaller runners & flow more??? B/C they are a MUCH better design than the LS6
There is a lot more to it than all this but I wanted to point out a few key points. I am sure I missed a lot & others can fill in the gaps.
"I think where I'm getting confused is when you throw "milling" into the mix. By milling the heads, it helps increase compression even more, hence increasing the velocity of movement of air through the heads (please correct me if I'm wrong on this). Can you guys give me a simple explanation as to how this is accomplished?"
No, by milling the heads you ^ compression which = more torque/power.
Old 02-27-2008, 02:24 AM
98redbird, how much power is your setup making?
Old 02-27-2008, 09:06 AM
CALL911's Avatar
This is generally the best advice on here. If you have the MS4, you won't be able to do the 5.3 stage 2.5 heads without flycutting the pistons. The MS3 will be fine with them, but the MS4 you will have to flycut.
LS6 heads will be fine with the MS4 as long as they aren't past stage 1. Past that and you'll also be looking at flycutting the pistons.
Now, if flycutting the pistons is no big deal, then I would mill down the PRC 5.3 stage 2.5 heads over the LS6 heads.
Old 02-27-2008, 09:12 AM
Gun5's Avatar
TSP PRC 5.3 Stage 2.5's - 220 Runner
208 @ .300
257 @ .400
290 @ .500
317 @ .600
$1,209
TSP PRC LS6 Stage 2.5 - 230 Runner
209 @ .300
258 @ .400
295 @ .500
316 @ .600
$1,699
TEA 5.3 Stage 2.5 - 220 Runner
207 @ .300
252 @ .400
290 @ .500
317 @ .600
$1,699
TEA LS6 Stage 2 - 230 Runner
219 @ .300
271 @ .400
308 @ .500
320 @ . 600
$1699
Old 02-27-2008, 09:58 AM
Midnight02's Avatar
Thanks cdoggy...that was a very helpful explanation. This is all starting to make sense!
Old 02-27-2008, 10:00 AM
Midnight02's Avatar
Good advice for those using the MS line of cams, however I have a Trick Flow cam that is slightly milder than a MS3. I should be able to comfortably use either heads without flycutting, so I've been trying to figure out which is better for my setup.
Old 02-27-2008, 10:12 AM
STRIPSTAR's Avatar
I have the 5.3s and a 230 cam. I didnt have to flycutt with the. 40 gasket but i didnt have enough room to mill. I would recondmend the 5.3s with that cam. The cam is similiar to mine and I'm 450+. Ls6 heads would be better in my opinion with a larger cam, milling and flycutting. So keep it simple and just bolton 5.3s and use a smaller gasket.
Quick Reply: PRC 5.3 vs PRC LS6 heads
