SLP Brake Control Solenoid, 98-02 Camaro/Firebird
Old Mar 8, 2008 | 08:35 PM
Buster99's Avatar
Default SLP Brake Control Solenoid, 98-02 Camaro/Firebird
Brand new, never installed. Directions included.
Asking 120 shipped or best offer.
Old Mar 8, 2008 | 09:28 PM
Gun5's Avatar
can u keep ABS?
Old Mar 9, 2008 | 12:57 PM
Buster99's Avatar
Yes, it doesn't intefer with ABS.
Old Mar 9, 2008 | 10:04 PM
SS SLP2's Avatar
LINE LOCK INFO
IS hole behind pcm , but I drill hole beside steering colum also ( drill from inside out ) put a peace of rubber hose in hole ran wire inside hose, then use same type wire wrap as GM,tie wrap to the big rubber hose comming over master cyl
I also mounted switch in ash tray
I have used this unit for 7 YEARS with NO problems ( well yes one problem :::SLICK tires )
PS ::Connect brake line to master cyl and line lock ,the second line which goes to ABS block start it but leave it loose,remove cap from master cyl and let the lines grivity bleed watch the loose connection untill all air is out and run pure fluid ( may shake the line a little to help bleed ( REMEMBER BRAKE FLUID WILL REMOVE PAINT
I placed plastic sheet over fender)if does not gravity bleed blow into master cyl and have some one watch for fluid at ABS block >>>THIS way you do not have to bleed the brakes from under car- I had no problem of any kind
Sorry for the long post, hope it helps
Johnny
Old Mar 9, 2008 | 10:19 PM
mavedawg04's Avatar
I'll take if for $100 shipped.
Old Mar 9, 2008 | 10:34 PM
renxwar's Avatar
Is this everything I'll to get it going?
Old Mar 10, 2008 | 10:24 PM
mavedawg04's Avatar
Is this for sale I will definately buy it from you just let me know how to pay you.
Old Mar 13, 2008 | 09:33 AM
Buster99's Avatar
Sold!!!
