Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Startup Vid of new 385ci Marine Stroker
Old 03-22-2008, 04:00 PM
Ryan02SS's Avatar
Default Startup Vid of new 385ci Marine Stroker
The boat is ready to hit the water now. Waxed, new motor in and new HD drive on. I fired it up yesterday to make sure everything was right. Weather looks promising for next weekend. Sunny 60's so the water test is not far away. I just need $1.50 gas to come back.... :mrgreen:
http://www.youtube.com/watch?v=ORkMT3JMWu8
Engine Specs....
010 4 bolt SBC, bored .040", 0 decked, line honed,
ESP 4340 3.750 crank, ESP 6" 7/16" H beams, Mahle forged FT's 5cc, C77H bearings, Hines Balanced
Melling Racing #10555 oil pump, Hamburgers 7qt marine pan, full length windage tray.
FluiDamper harmonic balancer,
AFR 190cc heads, 73cc, further ported by Carl McQuillen Racing Engines, Isky 6105 dual valvesprings,
Marine Kinetics "RMbuilder" custom Hyd Roller 234/240 .580/.568 112+4
Morel Retrofit Hyd Roller lifters
Smith Bros .083" wall pushrods
Edelbrock RPM Air Gap port matched to AFR port
Holley HP 750 DP
Lunati Voodoo Widebody 1.5 roller rockers
GLM aluminum manifolds
FastGlass Stainless 22" long dry risers
Full MSD ignition setup, coil, wires, dist, 6AL,
10.07-1 SCR
Old 03-24-2008, 11:32 AM
jmm98LS1's Avatar
Sounds badass!!
Old 03-24-2008, 11:58 AM
1 FMF's Avatar
post a vid of your avatar !
why not 1.6 rockers?
Old 03-24-2008, 03:08 PM
Ryan02SS's Avatar
The lobes were designed around a 1.5 rocker ratio vs the 1.6.
I wish I had a video of the avatar!
Old 03-29-2008, 09:11 PM
Badass355ciz28's Avatar
sounds pretty good, bet that will make some waves now
Quick Reply: Startup Vid of new 385ci Marine Stroker
