Bent Suspention!
Bent Suspention!
I was working on my exhaust cutout because it had seized up from rust while iw as under the car i got to noticing one of the control arms "i think thats what its called" was bent probably from a hitting the dear a few months ago! I looked on the other side and its bent to accept the one towards the rear of the car accept the one towards the front. Hopefully my warranty will cover this!
Yea your right looks like BMR makes aftermarket Lateral and trailing arms for W-bodys. After looking at how easily these things bend for anyone who drives aggressively might want to look at there arms and make sure they are still straight.
The old W-bodies did not have tubular trailing and lat arms...but I think we do. Not sure if the BMR is going to be any better than what we have already...but if yours is bent, you might as well just replace it with something good anyway.
EDIT: Before you go ordering stuff...that might not be the trailing arm...the one on the left could be as well. Lemme dig up my parts list.
EDIT2: It's listed as the "Front Knuckle Rod" - #10329691 - $86.47 (as of winter, '05, so it's bound to be 2x that now)
I'm going to see if i can get it replaced under warranty first. Looks like the trailing arm is fine it looks really stiff. But the lateral arms feel and look cheesy as hell. The trailing arm is the square arm that runs parallel with the vehicle.
You can see the before and after pictures the BMRs are allot thicker.
If you look down there its very straight forward they will work they are adjustable as well if you are interested in these kits then just email them I'm sure they will tell you what i have.
I dont think the wbody suspension has changed much???My old gp gt had these v shaped trailing arms and i think gm put on there gmpp trailing arms on the ss and gxps.Im wondering if BMRs trailing arms r bigger than ours?
I don't think its really the trailing arms that are the problem its the lateral arms after doing several 360's at 70mph only the lateral arms where bent
I labeled everything to the best of my knowledge after googling for a while
and as buffalo said they call it front knuckle rod :-\ so i'm assuming the other one is the rear knuckle rod.
I dont know if warranty will cover ur problem all they could say was that u were playing dukes of hazards or something like that or i could be wrong?But ya i think that kit would be good for our cars
Years ago when i had my '89 GPSE I ran over a truck tread in North Carolina once...Slapped te fuel tank and tore my muffler off from the pipe... I had to drive another 400 miles back to NY sounding like I was in Nascar, so loud...
Same car My parking brake froze in the winter and I was trying to loosen it up as I was rocking the car. In reverse the right rear tire went off the ice and cought on the concrete and bent the trailing arm.... though only 2 bolts, it was not easy to replace...
The ******* idiots at this dealership say they don't see anything wrong with my suspension and charged me 50 bucks i could not get there in time to show a tech the problem so now i have to drive BACK there tomorrow and show them on a lift because they can't tell a straight line from a giant ***** in there *******. Does anyone have any pictures of there lateral arms so i can compare ? thx
