1971 Chevelle LS1 6 Speed swap From the Beging
Old 04-06-2008, 08:38 PM
71protouringls1's Avatar
Default 1971 Chevelle LS1 6 Speed swap From the Beging
I bought a 71 chevelle 4 months ago thinking it was done. The moter ended up having a dead cyclinder, so I decided to do a Quick swap. It did not go so quick. The frame and floors ended up bieng in very bad shape. The frame was completly rusted out. So here is my story. Feel free to ask any ?'s. I'm still learning as I go.
Old 04-06-2008, 08:45 PM
Default I Finally fond a motor
I ordered the first motor from a local salvage yard for $3500 which I though was a steal. When it showed up there was was no 6 speed trans attached like I was promised. So I waited anouther week and they finally fond me one. So here it is. I jump right in a did the first test fit.
Attached Thumbnails 1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-002.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-003.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-004.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-014.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-006.jpg
Old 04-06-2008, 08:49 PM
Default After the first test fit bad news!!!!
The good news is the motor and tranny fit. (second try). The bad news is I fond out the frame is in bad shape and beyond repair. So we took it off
Attached Thumbnails 1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-025.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-027.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-030.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-034.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-033.jpg
Old 04-06-2008, 08:52 PM
Default Here are some pics with the frame off
Hre are some pics of the frame off
Attached Thumbnails 1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-036.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-037.jpg
Old 04-06-2008, 08:56 PM
Default Finally got a new frame
After a week of hunting I finally got a frame. It was out of a 69 El Camino. The guy at the salvage yard said it was the same as the chevelle. HE WAS WRONG!!! I have to take 4" out of the middle and 6" out of the back. But it will be worth it. This frame is fully boxed and is in great shape.
Attached Thumbnails 1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-038.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-041.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-043.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-044.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-045.jpg
Old 04-06-2008, 08:59 PM
Default Here is how i shortend it
This is a lot of work hope it is worth it
Attached Thumbnails 1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-048.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-047.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-052.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-055.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-058.jpg
dochall22's Avatar
sorry bout the uck with the cyliner, and shiity frame, keep up the pictures as you put it back together!! i've got a 454SS Chevelle I'm dying to put a 454LSX in!!!!
Old 04-06-2008, 09:03 PM
Default Had to make a new cross member
I had to make a new cross member because of the boxed frame. I just to some measurements off the old one since i knew it fit
Attached Thumbnails 1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-065.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-063.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-067.jpg
Old 04-06-2008, 09:05 PM
Default Finally got the frame welded up and can start test fitting
Test fit front susp.
Attached Thumbnails 1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-077.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-076.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-073.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-078.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-086.jpg
Old 04-06-2008, 09:08 PM
Default Everything fits off to powder coating
Here are all the parts
Default sorry here are the pics
Sorry
Old 04-06-2008, 09:11 PM
Default one more time
I will get it right this time
Attached Thumbnails 1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-095.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-096.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-099.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-100.jpg
Old 04-06-2008, 09:14 PM
Default Back from powder coating
It looks even better than I though. It matches the car perfect. I though Powder coating was a lot more expensive. He only charged me $300 for everything.
Attached Thumbnails 1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-106.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-107.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-108.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-112.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-114.jpg
Old 04-06-2008, 09:16 PM
Default Finally get to bolt things on that will stay on
This is my favorit part. Bolting on new clean shinny parts
Attached Thumbnails 1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-115.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-116.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-118.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-125.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-122.jpg
Old 04-06-2008, 09:20 PM
Default Headers didnt fit
Headers didnt fit, so I made my own. I used the Ls1 flange. A Camero big block on the driver side and a chevelle big block on the passenger. Then welded it all togerther. It took alot of time but I think they came out nice.
Attached Thumbnails 1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-126.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-129.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-131.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-136.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-137.jpg
Old 04-06-2008, 09:23 PM
Default Finally got the front and rear done
Its almost ready to roll
Attached Thumbnails 1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-139.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-133.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-134.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-135.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-138.jpg
Old 04-06-2008, 09:28 PM
Default Its ROLLING
It rolls and steers. I just have to put the posi rear end and gears in. The brake lines and air lines for the air ride and the chassi will be done. O ya I ordered new wheels and tire also. 18x 9.5" out back and 18x8" up front. It sure sits low. Its going to look bad ***
Attached Thumbnails 1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-141.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-144.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-142.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-145.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-143.jpg
Old 04-06-2008, 09:57 PM
jerrad's Avatar
Looks great man. What paint/interior are you going to go with?
Old 04-06-2008, 10:22 PM
bczee's Avatar
Great going.. keep up the work and the posting of pictures.. what engine adapter did you use (or if you made them, what style ?)
After looking at your pictures. I sure remember what you are going through, but I was lucky I didn't have to rebuild my frame.. good going on it.
Old 04-06-2008, 11:42 PM
Default paint & interior
Here are some pics of the paint. It was painted a month befor I got it. As for the interior, it is all originol. Black wih buket seats. I want it to look close to stock but drive like a new car.
Attached Thumbnails 1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-094.jpg   1971 Chevelle LS1 6 Speed swap From the Beging-ls1-chevelle-033.jpg
Quick Reply: 1971 Chevelle LS1 6 Speed swap From the Beging
