engine parts, o2s, yank cross, truck manifolds
Diamond pistons coated boost pistons, top with heat reflecting and sides with anti friction coating. 4.010" bore, 1.230 comp. height, set up for 6.200" rod, stock stroke. 28cc dish. These were just under 1500 new after coatings. comes with dual spiral locks, and pins. NEVER USED (rated for well over 1k hp)
Total Seal rings for above pistons. best of the best here, also BRAND NEW. almost 300 new (these babies can take lotsa pressure/heat)
Eagle 6.200" rods. stock clearances, dyno time only. ARP L-19 rod bolts installed (rated at over 1khp with the L-19's installed)
parts are setup for an iron block with a stock crank
$1150 shipped sold
yank th350 or powerglide crossmember $140 shipped
bosch 13111 o2 sensors used for some dyno pulls then removed almost new $100 sold
new truck manifolds with shields includes nut and studs in perfect shape $85 shipped sold
stainless T6 flange $40 shipped sold
$1150 shipped sold
