Ls1 Gauge Cluster
Old Apr 15, 2008 | 09:54 PM
SBcamaro's Avatar
Default Ls1 Gauge Cluster
I have 2 gauge clusters one has 43k it is out of a 02 LS1 65.00 shipped & one has 79k it is out of a 99 LS1 50.00 shipped. Both works perfectly.
Old Apr 19, 2008 | 10:28 PM
SBcamaro's Avatar
bumpftn
Old Apr 20, 2008 | 11:31 PM
99corvette's Avatar
How hard are these to change out? I am very interested.
Old Apr 21, 2008 | 08:05 AM
SBcamaro's Avatar
Default gauge cluster
there not that bad It take about 45 min.to change them out.
Old Apr 21, 2008 | 11:42 AM
Duffster's Avatar
it's easy to change out (bump by the way)
like a 7mm socket to remove two screws in the panel/cover, then the same w/an extension to remove the 4-6 screws (ain't done it in a year - don't remember exact #)
drop your steering wheel to lowest angle and pull the cluster out. SOME are tight and need to drop whole steering column about 3/4". Firebird/T/A's are easier because of the design of the upper dash cover (no steering wheel drop at all).
Good luck.
Old Apr 21, 2008 | 01:41 PM
Mike Cordero's Avatar
Default cluster
Can you sustain the 50.00 shipped to 00680 (Puerto Rico)? You may consider USPS which is a lot cheaper than UPS? Let me know, thanks.
Old Apr 21, 2008 | 02:49 PM
99corvette's Avatar
I guess my main concern would be the mileage, would i keep my mileage or would i get the mileage from the cluster?
Old Apr 21, 2008 | 03:12 PM
SBcamaro's Avatar
Default cluster
sorry but I can ship to Puerto Rico for 50 shipped It would cost about 10.00 more to ship USPS puerto Rico.
Old Apr 21, 2008 | 03:18 PM
Chief Z's Avatar
The mileage is stored in the cluster. You could get the dealership to set the new cluster. Legally they need to see your actual mileage off your old cluster. Or... you could just install it and not sweat the details. Super easy to change. I have had mine in and out in 10 minutes. Changed to a white luminescent faced overlay. (That took a while.)
Old Apr 21, 2008 | 03:20 PM
SBcamaro's Avatar
Default cluster
You can change the mileage readout thats in your gauge cluster with this one its easy to do.
Old Apr 21, 2008 | 04:37 PM
99corvette's Avatar
ok ill take the one for $50.00 shipped, whats your pay-pal.
Old Apr 21, 2008 | 04:48 PM
SBcamaro's Avatar
Default cluster
sburks1@aol.com
Old Apr 21, 2008 | 05:00 PM
euroman's Avatar
Money Sent
Old Apr 21, 2008 | 05:06 PM
SBcamaro's Avatar
Default cluster
Originally Posted by euroman
Money Sent
THANKS will get sent to morrow USPS
Old Apr 21, 2008 | 06:27 PM
Vindictive98LS1's Avatar
can you change the milege to match yours by yourself? couldnt you just swap something?
Old Apr 21, 2008 | 06:50 PM
99corvette's Avatar
money sent for the 79k cluster.
Old Apr 21, 2008 | 06:51 PM
SBcamaro's Avatar
Default cluster
yes all you need to do is unplug the mileage digital read out in the cluster, its a little harder pluging it back in you will need to use a pair of needle nose pliers .
