What is the best cam for stock LS1?
Old 05-15-2008, 03:12 PM
01stripperSS's Avatar
Default What is the best cam for stock LS1?
i want a cam i just need some info...
Old 05-15-2008, 03:52 PM
99blancoSS's Avatar
Here ya go!
https://ls1tech.com/forums/sponsor-sales-specials/918597-edelbrock-lsx-430-hp-cam-no-tune-required.html
Old 05-15-2008, 05:30 PM
BREWS02WS6's Avatar
Probably the stock one until you get some supporting mods to go along w/ it. Check the external engine section for lots of exhaust options.
Old 05-15-2008, 06:18 PM
2000Hawk's Avatar
Your sig has lid, and catback, those your current mods not including the 100 shot? First get yourself some longtubes, hookers tuck up nicely, and TSP has just come out with some reasonably priced 1 7/8 LTs so check those out also. After that consider whether you want an off the shelf cam, or if you want someone to custom spec one to what you want. I can't see you going wrong with a custom spec'd cam since it done to the performance you want.
-Joel
Old 05-15-2008, 06:31 PM
LS1-NAVY's Avatar
Tr224
Old 05-15-2008, 08:55 PM
MIKE02WS6's Avatar
First, figure out what you want to do with your car
Then, Research
Next, decide on your supporting mods cause you will need more than just a cam. Depending on your choice of cam, valve springs, moly rods, install kit, full exhaust, possibly gears, etc, etc,
Then, Research
You will get 1,000,000,000,000 different opinion on cams, from little to big, from under the curve power, to peak number cams.
Then, Research
Next, Decide on what cam you want to get for your car.
Then, Research
Finally, take your time in deciding, there are right ups and reviews on just about every cam out there on the market. The Search button is your best friend here.....
Old 05-16-2008, 02:30 AM
2000Hawk's Avatar
Well said ^, what cam may i ask are you running mike? You seem to be putting don't some stout numbers.
-Joel
Old 05-16-2008, 03:20 PM
dankl's Avatar
You gotta let your car inhale and exhale, i.e. intake and exhaust, before you can even consider a cam swap.
'01 Camaro has the LS6 intake manifold, so that should be okay for now, although mine is holding me back. You have a lid already, so your "inhaling" should be okay for now.
Definitely need headers, go longtube w/ Y-pipe or X-pipe or H-pipe back to your catback.
Now you can research a cam. If this is your daily driver and only car, I would suggest not going much bigger than something in the mid 220 duration and between .560 and .580 lift, this way you won't have to replace your valvetrain every x-number of miles (depending how hard you drive the car)
Along with any cam swap, you'll need supporting mods to your valvetrain.
Best thing to do is RESEARCH as much as possible. Make some phone calls and listen to advice. Don't get suckered into throwing the largest possible cam in this car if it's a DD.
Old 05-16-2008, 04:49 PM
MIKE02WS6's Avatar
-Joel
Its a Rapid Motorsports custom cam. I am unable to give out the exact specs for my cam. Maybe this thread would help you.
https://ls1tech.com/forums/eastern-members/919289-dominator-2-cam-tfs-heads.html
Quick Reply: What is the best cam for stock LS1?
