317 truck heads and other 6.0 motor stuff.
have a pair of 317 truck heads with only 60k miles on them, complete not taken apart Aluminum heads. Usually used for forced induction and can be ported to flow over 300cfm.
250 firm
6.0 truck intake complete with rails and injectors with 1 drive by wire tb and one cable tb also 60k miles. 80 firm sold
ONe top cover and pair of valve covers with front and rear cover also 50 firm sold
Pair of 02 sims for f-body 35 firm
I have two sets of truck exhust manifolds best used for front mount turbo set up 30 for a pair 1 pair sold
Every one hates tire kickers
I bought a whole 6.0 motor and only really want the block.
Have rods still on pistons also 30 sold
truck oil pan 25
truck coil packs once again all their on brackets 50. sold
good truck water pump 30 sold
4th gen f-body power steering pump with pully and bracket 50
and another set of iron 6.0 truck heads 82k complete 50
and two sets of rockers on bars 45 each.
250 firm
truck oil pan 25
Possibly interested in a set of the manifolds. Do they have the EGR fittings?
Also, my shop owner may be interested in the power steering pump, pulley and bracket.
Also, the valve covers and front and rear covers.
PM me a price on all that stuff shipped.
yes the manafolds have the egr fittings. shipping might be a bit if you want them as you know they are iron probbley 35lbs each.
100+ shipping, shipping would probbley be a good bit so i took 30 off those things to offset.
i have a crank but it needs turned. Did not spin a bearing or anything. would take 50+shipping for it. i was planning on keeping it but i have two so no big deal.
pretty sure i have the bolts from the bracket to the pump but not sure for the ones that go from bracket to head. pully is brand new from dealer nothing wrong with it.
yes have the pistons and connecting rods all good shape, was planning on rebuilding with new rings but if i sell the crank then i might as well sell them also. their the dished pistons out of an lq4 still on rods.
if not, how much for all 8 with rods shipped to 78584
yea i weighed them later 15lbs each lighter then i thought. yes their the 4inch bore pistons. i would sell them all for 30+shipping.
power steering pump is probbley sold.
heads have not been checked, just pulled and setting here.
