Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Camaro Drag Race Car partout
Old Jun 16, 2008 | 06:01 PM
romanss's Avatar
Default Camaro Drag Race Car partout
I am going to try to get rid of the big items first. Obviously I can't sell the rearend before the body. Or computer before engine. I will reserve first come first serve. I would prefer to sell the big stuff locally or pick-up.
Ask questions.
All prices are plus shipping.
This is off the top of my head, so I will have stuff to add later.
Engine:
441 NA 16.5:1 LS2 built by W2W
Custom Ross pistons
GRP alum rods with bolt upgrade
Lunati pro billet crank, lightened
billet main caps
Cam Motion Custom NA grind Cam
resleeved LS2 by R.E.D.
dry sump (sale pending yb)
afr heads
$11,000. I am willing to separate the dry sump system and heads.
pending sale for whole motor.
Heads:
225AFR heads cnc'd by ET performance
titanium valves 2.150, 1.65
Jesel rockers
PSI valve springs
$2000 if not sold with motor (sale pending to Kingsize if motor isn't complete)
Dry Sump
ARE dry sump pan
Dailey pump
Peterson oil tank
prolite -20 lines (prob $700-800 in line and fittings)
$1600 if not sold with motor (sale pending yb)
Body:
custom candy blue paint with "real" flames
carbon fiber Joe VanOverbeek pin on hood
14 point custom chrome moly roll cage with swingouts
was certified a few years ago.
$5000 for body, panels, hood, cage, interior
pending sale
Rearend:
Billinsley fab 9" rear narrowed 5/8 inch each side.
5/8 wheel studs
aluminum center section
4.30 rear w/spool
35 spline axles, star flanged
$2,000 pending sale
Trans T56
G-force internals 1thru4
Viper output shaft upgrade
Steel shift fork
billet keys
$2,200
Kooks stainless 1 7/8 to 2" step headers w/slip on collectors $700
(small dents and scrapes on collectors and 1 primary rerouted to clear steering shaft)
Borla XR-1 3.5 race mufflers $160/both(scrapes from touching ground)pending sale
McLeod "soft loc" clutch with alum flywheel $600
Pro5.0 shifter w/lous short stick $150 SOLD Bad Blue WS6
ARE tubular k frame and A arms $300(pending fitz 98ta)
BMR extreme torque arm $300 (needs the crossbar)
BMR extreme sway bar $250 (needs the housing pads and frame brackets)(pending Jeff LSFFA)
60" competition eng. wheelie bars $100 (need the weld on housing brackets)
Wolfe Racecraft offset LCA's $170 pending sale
Frnt/rear Hal 12 way shocks and front springs. $450pending sale
Custom DTS Chrome Moly Driveshaft $300
aerospace front/rear drag brakes $500(pending 1984CamaroZ28)
Aeromotive Pro-Series Fuel Pump, P/N 11102 and regulator $400 (sale pending)
Summit 5 gallon fuel cell $50
BS3 engine management w/ wide band $1500 SOLD
29.5 x 10.5 slicks on 15x10 7.5 b/s weld draglites $500
26 x 4.5 Moroso DS2 on 15x3.5 weld draglites $300 (pending Jeff LSFFA)
front suspension limiters $30
Meziere blue water pump $200 (pending fastrc)
Meziere painted black water pump (missing connector) $200(pending fitz98ta)
open trailer $1500 (will sell after car is gone)(pending)
TnT F2 ring with soleniods, ring, jets and 10lb bottle $400
10 lb NOS bottle. $120 SOLD
Nitrous purge solenoid $80
Added June 16th
Chrome moly driveshaft 42 3/8 center to center 1350 spicer joints $300
LS6 heads 2.150, 1.65 extreme duty valves, o ringed, double springs, flowed in the 320 range They have a few cracks $250 as is.
90mm fast t.b. $300
10 x je pistons 14.5 c.r 4.125 bore with 7 x carillo rods for 4.125 stroke. $500
Local pick up
28x10.5 w $75 about 1/2 life left
2 x 275 40 r17 goodyear eagles $50 ea
3 x C16 5 gallon pail $50 ea SOLD
1 x C44 5 gallon pail $200
If the picture doesn't work:
http://rides.webshots.com/photo/2396...32769399NHkwqV
Thanks for looking.
Roman
Old Jun 16, 2008 | 06:19 PM
fitz98ta's Avatar
pm on the k-member and a-arms!!!
another one on the black water pump
Old Jun 16, 2008 | 06:37 PM
SSwanner's Avatar
front coilovers & aerospace front/rear drag brakes. PM me some details!
Old Jun 16, 2008 | 06:38 PM
fastrc's Avatar
PM sent on both Meziere pumps.
Old Jun 16, 2008 | 07:06 PM
drozd_ws6's Avatar
PM sent on Frnt/rear Hal 12 way shocks and front springs
Old Jun 16, 2008 | 07:45 PM
SSPerformance's Avatar
if thats for both front and back PM me a shiped price will pay u now
Old Jun 16, 2008 | 07:46 PM
also are they street pumps or race
Old Jun 16, 2008 | 08:00 PM
Josh@KY-Turbo's Avatar
I will take the Aerospace front and rear drag brakes for $500.
Old Jun 16, 2008 | 08:18 PM
romanss's Avatar
I have a couple of corrections. I apologize.
The k frame doesn't have engine mounts. I ran a motor plate. It is also setup for a manual rack.
The 1 blue pump took a hit in the pulley and is dented. I change the price to $200 on this. It needs to have the pulley replaced. It works great, I am still running this one.
I am a bit overwhelmed with pm's so please give me a bit to get to all of them.
And I am adding some stuff.
Thanks,
Roman
Old Jun 16, 2008 | 08:25 PM
Sorry I didnt catch the above post before mine.
shot me ur pay pal so i can pay u for the brakes
np dude
Old Jun 16, 2008 | 08:58 PM
romanss's Avatar
They are the drag race setup.
Roman
romanss's Avatar
Thanks,
Roman
Old Jun 16, 2008 | 08:59 PM
JL ws-6's Avatar
Race your car!
WOW roman sorry to hear you're parting the car out.
I wish I had some $ left, I see alot of parts I'd love to snag.
Good luck with your next project!
Old Jun 16, 2008 | 09:01 PM
romanss's Avatar
Thanks man.
I am sorry too, but that's the way it goes.
Roman
Old Jun 16, 2008 | 09:03 PM
fastrc's Avatar
PM back to you on the Blue Meziere Pump.
Old Jun 16, 2008 | 09:07 PM
Cliff's Avatar
Second in line for BS3. If your sale doesn't work out please pm me. Thanks.
Old Jun 16, 2008 | 09:08 PM
whats ur pay pal so i can pay u for the brakes
romanss's Avatar
I will
Thanks,
Roman
