Crane Cam/ Vinci Power Programmer Tool
Hey all heres a great programmer works on the following cars
programmer # 1202-008
99-04 corvette ls1/ls6
99-02 camaro / firebird
this has just been reflashed and is unlocked for any car listed above...these things are over $400 dollars new but this one is lower than that it has alot of things you can tune on your car Delivers up to 30 HP rear-wheel increase from stock! I'll do $365.00 shipped pm me if your interested in it.........thanks heres straight form the site info on it below......
Delivers up to 35 Ft. Lbs. rear-wheel torque increase from stock!
Easy Plug-n-Go installation takes only minutes!
Easy push-button, hand-held programming. No laptop computer required!! Lets you recalibrate for taller/shorter tires, 25" to 44" on most trucks!
Lets you recalibrate for higher/lower (numerical) rear axle ratio from 2.73 to 5.13 for most applications!
Allows you to match speed limiter to the speed rating of tires!
Provides 30+ different tuning parameters for stock engines (most trucks)!Provides tuning for three Crane Powermax Truck-Power cam profiles plus allows tuning for stock cam!
Allows adjustment of idle speed in 50 RPM increments!
Optimizes transmission shift points for new Powermax Truck-Power cams!
Lets you choose shift points for stock cams!
Calibrated for all truck auto transmissions including Allison 5-speed!
Allows tuning of high-flow injectors for supercharged applications!
Lets you ?fine tune? your spark advance curve plus-or-minus 10% from the Power-Tuner programmed curve that you select!
Delivers performance increases without changing to colder thermostat and harming fuel economy!
Lets you adjust to your grade of fuel: Low, middle, or high octane, with auto adjustment if low grade fuel is accidentally used in high octane mode!
Easy return-to-stock anytime you choose!
Performance settings can be infinitely changed!
PowerMax Power-Tuner is specifically calibrated to your specific vehicle!
Reads diagnostic trouble codes and provides easy "clear code" function!
Thank you Brandon!
Great seller, wonderful person to deal with.
Put the tune in today, and corrected my speedo for the 18's I have on the rear now
Everything worked just like it is supposed to. The new shift firmness is great!
Thanks again
jman
Everything worked just like it is supposed to. The new shift firmness is great! Thanks again
jman
