96 Trans Am partout
I started to part out my 95 TA because I could not find a motor for it and than came across this car. I will be using the car for the motor, trans, wiring harness, and pcm. All else will be sold. If you need something let me know. All parts will be plus shipping and paypal fees.
PARTIAL LIST OF PARTS
INTERIOR
Sail panels 45
Kick panels 35
Rear carpet 25
A4 Shifter 25
A4 Pedals 25
Sunvisors 30
Seat belts 35
Hatch divider 25
A pillars 30
Door sills 20
Under dash panels 10 ea.
Spare tire 30
Rear sail panel speakers monsoon 50
Pass. air bag 75
Dome light 5
Headlight switch 15
Glove box 20
Air bag module 20
EXTERIOR
Drivers side ground effect 95
T-Top conversion 300
Front brakes 70
Rear bumper 75
Front bumper foam support 20
Hood latch 10
Hood 50
Drivers side fender 75
DS headlight motor 50
PS headlight motor with brass gear 70
(3) center caps 5 ea.
K-member 75
Shocks 70
Springs 50
Rear end 3ch 3:23 250
Tail light harness 20
LCA'S 15
Panhard bar 15
Torque arm 20
Gas tank 40
Fuel lines 35
Throttle cable 30
Sway bars 45
Ebrake cable 25
Turn signal lenses 20
Radiator support 30
Washer fluid tank 15
Horns 15
Wiper arms 25
Hood hinges 20
PARTS SOLD
Door panels
PS GFX
HVAC controls
Fog light switch
Rear deck panels
Gauge cluster
Headliner
T-Top shades
Rear calipers
Steering wheel
DS airbag
E brake assembly
Radio bezel
Here are a couple of pics of the car. If any more are needed I will get them asap. Just click on the pics to enlarge.
INTERIOR
Sail panels 45
Kick panels 35
Rear carpet 25
A4 Shifter 25
A4 Pedals 25
Sunvisors 30
Seat belts 35
Hatch divider 25
A pillars 30
Door sills 20
Spare tire 30
Pass. air bag 75
Dome light 5
Headlight switch 15
Glove box 20
Air bag module 20
EXTERIOR
Front brakes 70
Rear bumper 75
Hood latch 10
Hood 50
K-member 75
Shocks 70
Springs 50
LCA'S 15
Panhard bar 15
Torque arm 20
Gas tank 40
Fuel lines 35
Throttle cable 30
Sway bars 45
Ebrake cable 25
Radiator support 30
Horns 15
Wiper arms 25
Hood hinges 20
PARTS SOLD
Door panels
PS GFX
HVAC controls
Fog light switch
Rear deck panels
Gauge cluster
Headliner
T-Top shades
Rear calipers
Steering wheel
DS airbag
E brake assembly
Radio bezel
Looking for the interior trim pieces behind side mirrors (triangular shape) and the sun visor mounts. If by chance you would consider letting one of each go, I just need the driver's side trim piece and passenger visor mount. Either way, I am interested.
Shipping to 90650. Thanks.
Not bad. The pass. side is sagging slightly. 55 shipped
The whole weatherstripping?
It has as small crack on one of the vents.
The air bag cover will stay with the dash. 25+ shipping for the center console piece.
20 shipped for both
I'll do 35. Shipping will be a little high because of size.
I don't see them pictured, but I'm interested in the fog light brackets if you still have them. I don't need the fog lights themselves, but if you don't want to separate, then depending on the price I'll take em to help seal a deal.
can you send me a pic of the top piece of the center consul just want to make sure it the one i need you can send it to me at Frankie8600@comcast.net or a pm thanks
no not the whole weatherstripping, theres 2 peices of hard rubber or plastice that go infront of and in back of the t bar, they slide into the groves on the t bar, the outter corners of the t-tops sit in them when on the car and they lock out water from getting in the middle front and back of the car.
Here are a couple.
can you send me a pic of the top piece of the center consul just want to make sure it the one i need you can send it to me at Fankie8600@comcast.net or a pm thanks
