MUST SALE,Nice Z28 383, 6 spd,
SOLD !!!! Now Dyno tuned .... Made 427 hp-428 tq NA.. and 639 hp-750 tq on 200 spray...
[/COLOR]
Asp pully
Slp air lip
Ported throttle Body
160 Themostat
CNC ported 5.3 heads hand finished 2.055 intake valves
Comp Double Roller timing chain
Katech ported oil pump
Comp hardened push rods
LG Motorsports G5x2 Cam 232/242 duration 598/608 lift at 112
Eagle 4" stroke crank
Lunati Rods
Mahle pistons 3.903"
Kooks 1 3/4 stainless long tube headers
3" SLP Dual Dual cat back with electric DMH dump or have 3" true duels for car
42lb FMS injectors
Harlen shift light
Harlen 2-step
Hurst line lock
Raceronix fuel system
T-56 with all new hardened internals, built by T-56 rebuilds.
Moser 12 bolt w/ 4.10 gears
30 spline axels
Eaton posi
Ram VDS 900 clutch
Updated slave
Ram clutch/MC
Pro 5.0 shifter
LG motorsports ajustable Panhard Bar
LG motorsports Torque Arm
LG motorsports relocation brackets
LG motorsports billit Ajustable solid LCA's
LG motorsports Sub Frames
Sphon 25mm solid rear swaybar
Right rear air bag
Poly tranny mount
1LE Rear springs
Custom 6 point Chromoly Roll Bar with removable side bars
Stroud 5 point harness
QA1 fully ajustable coil overs with 12 way shocks in ftont
QA1 12 shocks in rear
slotted and drilled zink coated brake rotors
Chrome ZR1 wheels
17/9.5 in front with 275/45 BF KDW's on front
17/11 in rear with 315/35 BF KDW drag radials on rear
wheels and tires like new
Sunoco Cowl hood. Fits great. painted base/clear underneath as well
NX Direct port Nitrous system with rails and Pahranna nozzles'
Nitrous outlet Dedicated Fuel system
Low preshure switch
Bottle heater with switch
Nitrous Outlet between rear seat bottle mount
Nitrous outlt Wide Open switch/Window switch
Nx purge
Nitrous outlet console switch
Nitrous wiring is awsome.. The intake,purge, heater.. all of it was wired in GM loom and Weather-Pac connectors so if for some reason something had to come off theres no cutting wires.. As you can see in the pics it done right.. Not wires running everywhere unloomed ..
Nitrous was just installed by Nitrous Outlet with custom Harness. Its a great job. Drive it anywhear with the air on. Car is in great shape. one or two small dings Car sits in shop year round and never sees bad weather. Interior is great and clean. Very Very clean car. Rearend is noisey when you let off the gas.
13,500
[/COLOR]
Asp pully
Slp air lip
160 Themostat
Lunati Rods
42lb FMS injectors
Harlen shift light
Harlen 2-step
Hurst line lock
30 spline axels
Eaton posi
Ram VDS 900 clutch
Updated slave
Ram clutch/MC
Pro 5.0 shifter
Right rear air bag
Poly tranny mount
1LE Rear springs
Chrome ZR1 wheels
Low preshure switch
Nx purge
13,500
I sure wish you would have come down this low a few months back when I was looking for another Camaro. I would have bought it back in a heartbeat at that price
This is a STEAL at this price.
