Parting out 02' Z28 Camaro
Old Jul 15, 2008 | 02:33 PM
Speed Demon's Avatar
Default Parting out 02' Z28 Camaro
Lots of parts for sale for half retail price or less.
Please send email or PM to inquire about a part. Car is still mostly complete, so lots of parts available.
Most of the body panels are not usable, however rear hatch glass is in good shape. Car has cloth interior but is in pretty rough shape. The console pieces are in fair to good shape though.
Here are a few parts that are available.
LS1 complete with PCM/wiring harness and accessories
Recently rebuilt by John West.
Has mild aftermarket cam with, CC918 valve springs and hardened pushrods.
Compression is 215psi to 225 psi on all cylinders. 35psi oil pressure at idle.
I'll find out cam specs when I pull the engine out of the car.
Engine sold.
T56 w/ bell housing $1000 - SOLD
Bilstein HD shocks (4) $200 sold
Eibach springs (4) $100 sold
Cooling fans $100 sold
Factory Hurst shifter $60 SOLD
Factory Monsoon CD deck $75 sold
Factory 16" wheels (2) $50 SOLD
Rear end w/o brakes non-traction control $250 (assume 3.42 ratio, will find out) sold
Driveshaft $100 SOLD
Wiper motor $10 SOLD
Radiator top mount/bottom of airbox $15 SOLD
Front cloth seats $40 for the pair (pick up only) driver side needs recovering SOLD
Poly trans mount $10 SOLD
Stock oil pump, 40k miles. $25 SOLD
Stock K-member $100 OBO SOLD
Stock Lower A-arms $40 OBO SOLD
Stock front sway bar $20 SOLD
Tail lights $15 each SOLD
LS1 intake, C5 w/o EGR provision $20 SOLD
body wiring harness SOLD
Power Steering cooler $40 SOLD
flywheel SOLD
Dash pad $100 prefer pickup SOLD
Stock torque arm $15
6 spd. trans cross member $40
Front Brake pads $10- plenty of meat left
Hood latch cable and pull handle $10
Trunk switch $5
Airbag control module $80
Stock 02' clutch $25
16" snowflake wheel has some damage, good spare $20
245/50/16 Kumho Ecsta 40% tread life, good for a full size spare $30
Passenger side T-top $70 minor scratches on glass
Steering rack (has one bent tie rod) $40
Gauge cluster $40
Gauge bezel $20
Rear hatch with glass $75, only glass is usable
Front brake rotors $10 each
Center console lower portion $50
Emeregency brake lever and cable $30
Airbag passenger $75
Radiator $15 end tank cracked, could be fixed?
A/C Condenser $30
Heater/Evap box with blower $100 prefer pick up
Gas cap and trim $15
Windshield cowl with sprayers $20
Wiper motor linkage $10
Daytime running light module $10
Glove box $25
Hood latch and cable $15
Front seat belts $15
Rear Seat belts $15
Sail panel $30 each
GM valve stem seals (16) p/n#12482062 NEW $20
GM truck intake gaskets LS1 style engine $20
Stock Amplifier $15
Brake booster $50
master cylinder $40
Dash with passenger side airbag $150, prefer pick up only
ABS block $80 (non-trac control)
Washer reservoir with pump $25
Radiator/front support $15
Fuel tank w/o sending unit $50
HVAC control $25
Headlight interior light switch $25
3 under dash panels (w/o trunk switch) $50
A-pillar panel $25 each
T-top latch pin cover $8 each
6spd. Pedal assy. $60
Horns $15
Harness Bar $150
Interior is Ebony in color
Have other misc. parts not yet listed, just ask, may have what you need such as:
HVAC vents
misc. nuts, bolts, brackets, plastic
Lots of other parts that are not listed, just ask.
Shipping not included. Paypal payments with debit or CC add 3%.
Old Jul 15, 2008 | 02:38 PM
94'BLKBRD's Avatar
miles on the bilstein shocks?
Old Jul 15, 2008 | 03:03 PM
Jayh's Avatar
Put me up for shocks if " 94 " dont want them.....could u still post the condition and mileage....
Old Jul 15, 2008 | 03:11 PM
Mileage on the shocks is uncertain. They look a whole lot newer and cleaner than the car though. Sorry for the vague info. I bought the car totaled to part out.
Old Jul 15, 2008 | 03:24 PM
94'BLKBRD's Avatar
Passing...
Old Jul 15, 2008 | 04:05 PM
wickedbusa's Avatar
Is the alternator available? If so, please send me a PM.
Old Jul 15, 2008 | 07:18 PM
blkdkz28's Avatar
you got a passenger side fron speaker?
Old Jul 15, 2008 | 07:32 PM
98MNBZ28's Avatar
do ytou have shifter boot w/mounting bracket?and whats the deal with the shocks
Old Jul 15, 2008 | 08:02 PM
67SS509's Avatar
10 Second Truck Club
What color is the interior?
Old Jul 15, 2008 | 08:19 PM
B1RDFLU's Avatar
are those springs lowering springs?? How many miles on the car? curious about the shock spring setup, and is it all four shocks and springs?
Old Jul 22, 2008 | 12:27 AM
Rushin's Avatar
Bump for good seller.
Old Jul 22, 2008 | 11:37 AM
It's the Eibach Prokit lowering springs and Bilstein HD shocks. I don't know the mileage on the shocks and springs. I'm trying to track down the previous owner to find out that info.
Old Jul 22, 2008 | 10:30 PM
GTA91's Avatar
I'll take the springs and probably the shocks. Can you get me some pictures to confirm what they are? You take paypal? Cash in hand... ready to buy, let me know.
Old Jul 22, 2008 | 11:55 PM
Tom01ss's Avatar
looking for both p/s lines that go to the cooler and the consol lid if black.Let me know
Old Jul 23, 2008 | 07:49 AM
Someone is supposed to pick them up today. If it falls through I'll get back to you.
Old Jul 23, 2008 | 09:41 PM
Jefro6996's Avatar
So are the shocks valved for the springs? im not sure if you mean the owner put on bilstein hd's and the prokit or if the car came from slp with he eibach lowering springs and matched bilstein shocks?? Let me know im very interested.
Old Jul 23, 2008 | 10:35 PM
Funkster's Avatar
What color is the interior? Also, what condition is the carpet in?
Old Jul 24, 2008 | 01:42 AM
tspence45's Avatar
Put me in line for the Eibach Prokit if the others fall through.
Old Jul 24, 2008 | 06:53 AM
blackfang's Avatar
How are the headlights? Can you email a pic to phil@svt4u2try.com
Old Jul 24, 2008 | 09:11 AM
supa ss's Avatar
What about the t tops
