Stock parts pile, covers, heads, intakes, tbs etc & aftermarket stuff FS
Old Jul 16, 2008 | 04:35 AM
GrannySShifting's Avatar
Default Stock parts pile, covers, heads, intakes, tbs etc & aftermarket stuff FS
$100 Aluminum driveshaft
$40 A4 LS1 Trans crossmember
$25 Rear DeCarbon shocks 15k miles
$25 LS1 Valley Cover
$20 AC Bracket/Tensioner
$25 LS1 Front Cover
$50 98 Flexplate
$25 98 Pair of Valvecovers
SOLD $35 Belt Tensioner 15k miles
$10 2x Baffle/Inserts that goes inside Fbody oil pan (bolted down with 10mm head 6mm thread bolts)
$50 LS1 Intake
$40 Stock injectors
$35 Stock fuel rail
LS1 3 Channel Brake backing plates, rear calipers, rotors
Stock Torque Arm
$20 LS1 Radiator Shroud/Lid Base
$250 806 Casting heads with PRC dual springs @ 1000 miles
$200 853 castings
$125 806 castings
$300 New 240/250 109 LSA Cam
$300 Like new Comp camshaft. We ground this for supercharged car, made 700 ft lbs of torque at 3800 rpm with Procharger. Broke trans on dyno and put more camshaft in to kill some torque. Maybe 2 miles on this.
Stock GTO Cam
Edelbrock Torque Arm
Comp 1418-16 Magnum Self Aligning Rocker Arms, 1.6 Ratio
$70 Comp 7.400 Chromemoly Pushrods
$20 Stock Balancer
$30 C5 Vette Clutch Master CYlinder
$180 860 Performance 4 AN auto Bottle Heater Brand New in Box 15% Off
Old Jul 16, 2008 | 04:38 AM
SOLD $500 Jesel 1.7 SS Series Shaft Rockers
LS1 Steering Rack
$15 Coolant overflow/battery tray
Monsoon Stereo system
$60 99 LS1 Waterpump
$50 2x 98 LS1 Waterpump
$100 NX Remote Opener, has leads off the opener but missing switch
$75 85mm MAF
$100 LS1 Fans
$40 Line Lock Solenoid
Low mile LT1 Corvette waterpump, CLEAN
LT1 Fbody Pump (good for guys wanting to do electric pumps, modify on bench and swap it once its done)
$225 PA LS1 k member, with mount stands, man rack mounts
LT1 Intake Manifold
$200 Ported LT1 Intake Manifold
$50 LS Truck waterpump
SOLD ARP LS1 Head Bolt Set
$75 2x Maf Translator
TFS 8.250 chromemoly pushrods
$15 Crank timing gear adj. from Cloyes Kit
$75 LT1 ABS Block
MSD 6A Box
LS1 AC Condensor
Brand new LS1 hurst shifter base
shifter/handle
$40 LT1 TB
LT1 Starter
Dynabatt small battery
Genesis small battery (need to check these out been on shelf for a little bit)
SOLD 2nd set stock injectors
$225 Stock 241 heads, these are the sand cast castings, little more consistant
LT1 Clutch master/slave/reservoir assembly
$40 LS1 clutch master cylinder
$20 LT1 Air foil
Make offer 2x FMU's
Corvette lowering bolts
$200 McLeod Adjustable master cylinder 5k miles
$75 chromemoly 7.400 pushrods
Autometer 6809 tach
$45 LS1 M6 crossmember
$35 LT1 A4 crossmember
$40 FTRA top piece (the funnel to the lid base, its just missing the flat sheet that tucks under the core support bottom. Had made a wider one for this, easy to do the same)
Old Jul 16, 2008 | 12:00 PM
I think this worked this time
Old Jul 17, 2008 | 09:51 AM
added some prices
Old Jul 17, 2008 | 10:24 AM
69lemansguy's Avatar
Brand new LS1 hurst shifter base... can you send pics to s69lemansguy@aol.com.
Old Jul 17, 2008 | 05:00 PM
LS1C5Vette's Avatar
how much for the ARP head bolts? I am interested
Old Jul 17, 2008 | 05:25 PM
$110 shipped
Old Jul 19, 2008 | 05:01 PM
Ryans99ls1's Avatar
is the clutch master cylinder an 01-02?
Old Jul 19, 2008 | 06:49 PM
give me a part number to check it against and Ill let you know.
Old Jul 19, 2008 | 07:30 PM
PadreSmith's Avatar
what year is the belt tensioner for?
Old Jul 20, 2008 | 05:57 PM
72chevelle6.0's Avatar
Info and picture on the TR224 Please. Todd@steglich.net
Old Jul 21, 2008 | 11:36 AM
Can you tell me the Mileage on the TR224
Old Jul 21, 2008 | 12:16 PM
EMail me guys
Old Jul 21, 2008 | 05:49 PM
Ryans99ls1's Avatar
GM Part #12570277
Inbox was full. Pm me back.
Old Jul 22, 2008 | 12:57 PM
EMail me guys
LTOne4Fun@aol.com
Old Jul 22, 2008 | 01:00 PM
hf6017 i believe was the last numbers stamped on the master. no gm part numbers listed on it. I dont believe there were any real differences in master cylinders thru the years, that part number is listed as 98-02... the slaves were changed up a bit for 01-up though
Old Jul 22, 2008 | 01:34 PM
Ego Killer's Avatar
I'll take the 98-99 TB does it have the sensors? I have paypal.
Old Jul 22, 2008 | 03:09 PM
Sommer86's Avatar
how much for the monsoon stereo? Is it CD? Also, What is the year of manufacture?
Old Jul 22, 2008 | 03:11 PM
still wanting the TR224
Old Jul 23, 2008 | 03:52 PM
72chev sent you email
