Torque arm relocation crossmember: BMR or UMI?
#43
Well I'm installing this thing. Would have been done hours ago but it doesn't fit right. The hole for the tranny mount won't line up (plenty of room for adjustment in the opposite direction tho ) I have an energy suspension poly trans mount, fit fine with the stock crossmember. I have removed the whole thing and enlarged the mounting holes with a dremel a few times. Anyone got any other ideas? I'm beginning to think they gave me one for the wrong tranny.
#44
Did you try installing it with out the torque arm to make sure everything lined up? The weld jig locates the mounting holes in the correct location to help prevent this, so I would like to see what is not lining up. Do the mounting holes line up and just not the transmission mount? Can you e-mail me a few pictures?
#47
Well it's not left to right issue, the tranny mount is too far forward to go thru the mounting hole. The whole crossmember needs to come foprward a bit to reach the hole. I can get like one side of mounting holes and the tranny mount in, then the other side is off. I'm just gonna keep dremeling. Maybe I'll modify the tranny mount holes a lil, that'd be easier than the thick steel on this crossmember.
#48
That is really odd, they always sit in there nice and centered... I am not sure what would cause that. The tubing can't move front to back on the fixture either or the entire item will change... I'm lost on what would cause this.
If you get a chance snap some pictures and e-mail them, it might help me.
#50
I noticed when i put mine in that i couldnt use a poly trans mount because with the stock rubber trans mount, it offsets to the rear so things line up. With the poly mount it wasnt offset and was thus too far forward and would not mount correctly.
#51
Well this explains it I guess. I got the thing on, had to beat the sh*t out of it tho. Didn't have a stock tranny mount around. Just dremeled out the holes some. I don't think I hurt the integrity of the piece, just may have rendered it unresellible in the future. This thing is a lil noisy, no where near as bad as the tunnel mounted torque arm I used to have so I think this will stay. I was not able to use the top set of mounting brackets for the arm, not cause the torque arm was hitting the tunnel but because the outer ta bracket would hit the bottom of the tranny. Didn't see any way around that. Thanx for your help guys. Next time my cars in the air Ryan I'll take some pics.
