FS:stock parts everywhere!!
I have much more than whats posted.Ask if you need something!
All prices are PLUS shipping unless otherwise noted.
Paypal buyers add 3.5%
aluiminuim driveshaft from a 2001 SS...Needs a cap for the u joint. $80
stock camaro tail lights 98-2002 $85 SHIPPED
guage cluster from a 99 ss with 104k miles $80 SHIPPED
stock ls1 coil packs or a 2001 with 44k miles $110 SHIPPED
stock raidiator and fans $150
complete front suspension off a 99 with 104k miles. includes k-member,a-arms,lower control arms,spindles,brake rotors,calibers,front sway bar and stering rack. $200
stock SS exhaust un cut! $60
oil pan off a corvette(99) $100
6.0 truck mainifold $60
6.0 truck wiring harness $50
6.0 intake with rails and injectors $50
Located in dallas tx.
Got a Camaro passenger side door bezel that goes around the handle and the window switch panel clips into it? I need ebony and will actually take both sides if you have them and the price is right.
The wiring harness, is it a drive-by-wire throttle harness or is it cable-op throttle? Does it have the connector for the 4L60E? Also, does it have any missing or damaged connectors? Thanks.
(I sent you a couple PM's in your other thread, but I'm not sure they're going through...)
