Garage cleanout sale
High on diesel fumes
Misc assortment of AN and factory style fittings. I don't want to ship these out individually. $40 shipped takes it all.
(1) -4AN hose end coupler
(1) -4AN hose end coupler (hose cover only)
(1) 3/8" pipe to -6AN 90*
(1) -6AN hose end coupler (hose cover only)
(1) 3/8" pipe to -6AN straight
(1) -6AN female to female straight coupler
(1) -4AN female to male 90*
(1) -4AN female to female coupler
(1) 1/8" pipe female to -4AN male 90*
(3) factory trans-style fittings with clips
(1) trans cooler in radiator fitting without clip
(2) clips for factory oil cooler fitting in radiator
Two lengths of -8AN steel braided line. One is 8ft and one is 15 inches. $35 shipped.
Autometer fuel pressure gauge, never used. The included sender works intermittently. Wiring harness has been cut - gauge side is intact with a decent length of wire attached, but sender side is gone. $20 shipped. **SOLD**
Rebuildable truck alternator. Charges but voltage fluctuates. Could be a bad diode or whatever straightens the AC current into DC. I believe it's a 130amp. $40 shipped.
Wiring harness specifically for a QTP electric cutout. Includes momentary switch, power plug, and connector. $10 shipped. **SOLD**
Two air filters. Both are 4" ID. $15 each shipped or $25 shipped for the pair.
Front coolant crossover and rear plugs. $15 shipped. **SOLD**
Hypertech 180* thermostat for separate housing/t-stat style water pumps. $20 shipped.
TWO electric fans, roughly 12" diameter. I know there are 3 pictured, but one is already promised to a friend. $25 each shipped. **SOLD**
U-bolt exhaust clamps, set of 4 $20 shipped
