**Gotta fund another motor build. Upgrade stuff for sale**
Old Aug 2, 2008 | 04:23 PM
chevroletfreak's Avatar
Default **Gotta fund another motor build. Upgrade stuff for sale**
I have to get some money to build me another motor. So, I have a few things for sale.
BMR black powdercoated tubular rear lower control arms w/ poly/poly bushings - $70
Ready for the dragstrip! BMR Trak Pak fits 3rd & 4th Gen.82-02 Camaro & Firebird. Relocates the torque arm front mount to prevent transmission tailshaft housing cracks. The shorter torque arm design moves the "instant center" rearward for improved weight transfer on acceleration. It has a rear adjuster to allow on-car pinion angle adjustments up to 6 degrees for dragstrip tuning and a polyurethane front mount. This is new, but it has been mounted. However, the crossbrace is brand new and has not been mounted. They both have a few scratches from being moved around the garage, but they are ready to perform. Original cost was $420 - save a ton..- $325
Brand new LT1 Optispark conversion harness. This harness plugs into the optispark on one end and into the wiring harness on the other. It works w/ 95-97 LT1 engines or 93-94 LT1's to convert the failure prone non-vented opti to a vented style. It is a direct plug-in requiring no modifications and is a direct replacement for GM part # 12130319 ELECTRICAL HARNESS 95-96 VENTED, RETAILS FOR $124. - $20!
Harlan red LED shift light. This was one of my favorite upgrades and helped me enourmously when racing. You'll know when to shift for sure.
Dimensions: 1" diameter by 3" long
Housing: Flat black painted Polycarbonate tube
Light: 6 RED high brightness LED's
Usable on all ignition systems (distributor, distibutor-less, 2/4/6/8 cylinders)
Adjustable in 100 RPM steps from 500 RPM to 12000 RPM without additional pills or modules
Originally $55 - $35
SOLD! 3" LS1 aluminum drive shaft.- $150 SOLD - TowShen!
SOLD! BMR silver powdercoated on-car adjustable tubular panhard rod w/ poly/poly bushings - $75 SOLD - think47!
I think that is it for now.
ALL SHIPPING WILL BE THROUGH USPS DOMESTIC PRIORITY ONLY. The cost can be calculated from zip code 09012.
Old Aug 2, 2008 | 07:40 PM
SVT THIS's Avatar
Shift light is mine check your pm
Old Aug 2, 2008 | 10:34 PM
think47's Avatar
any pics of the panhard rod,consider it sold if so
Old Aug 2, 2008 | 11:10 PM
It is the PHR002. Unfortunately, I cannot get pics at this time because my wife took the camera with her on vacation. I will post pics of anythng that is left when she returns at the end of next week.
Old Aug 3, 2008 | 10:11 AM
Driveshaft and Panhard are sold! Up top we go.
Old Aug 3, 2008 | 12:14 PM
LANDONZ's Avatar
ill take the LCA's can I get some pics to landonburks02@yahoo.com
Old Aug 4, 2008 | 12:24 PM
digitalsolo's Avatar
Is the shift light sold or no?
