How to fix your radio/door locks/windows etc from flickering.
Old 08-13-2008, 12:13 AM
phantomzer0's Avatar
Default How to fix your radio/door locks/windows etc from flickering.
Finally, here is the fix! No more spending 400 bucks to get this fixed.
https://ls1tech.com/forums/general-maintenance-repairs/883334-ls1-body-control-module-problems-fix.html
Big thanks goes out to Greg Crow for figuring this out and documenting it so we ALL can fix our problems!
Here is an exact copy of his post in his thread:
Originally Posted by Racr X
Not sure which Forum this should be under so please feel free to move this and delete this sentence.
I've had 3 LS1 cars over the past few years that had intermitent body control module problems. When your radio and power windows intermitently go on and off, it's a body control module problem. This must be somewhat common and most people probably don't know where the problem lies.
Today I took a shot at trying to fix the module itself as buying a new one is around $200. You can buy a used one but then you have to know the VIN of the car it came out of so you can get the VATS code and make a new ignition key for your car that matches the used BCM.
The BCM is located on the passenger side under the dash just behind the glove box. To my surprise, the entire circuit board is just sitting inside a black plastic box that unsnaps. Unsnap the box and remove the entire circuit board. I was able to isolate the problem to the main power circuit/plug-in. After playing the wiggle-parts game, I found that the relay just behind the plug was the problem. There are 5 solder joints holding the relay onto the board. One solder joint looked like it had a super tiny micro-crack in it. I heated that one solder joint and added some additional solder and whaddayaknow !!!! it fixed it ! Your mileage may vary but I would reheat each of the 5 solder joints.
Here is a picture of the circuit board with the 5 solder joints crudely circled. The bottom joint was my problem.
Just thought you guys would like to see this.
Greg Crowe
http://www.camarofirebird.com
If you take a look at Greg's second picture you will see what appears to be a "T" shape made out of some of those metal ends. From what I have gathered nearly everyone's problem comes from the bottom of the "T" shape. You need to look very, very closely to see the cracks. You may not be able to see them st some angles.
Apply your solder and you should be good! Awesome!
Old 08-13-2008, 12:16 AM
Sticky
Old 08-13-2008, 08:51 AM
Copy & Paste Moderator
VIP1's Avatar
Done. I added it to the FAQ sticky.
Old 08-13-2008, 01:27 PM
woopty wewt
Old 08-13-2008, 01:31 PM
KEE AUDIO's Avatar
Awesome information!!!! Thank you!!
Old 08-13-2008, 03:13 PM
VIP1's Avatar
Originally Posted by phantomzer0
woopty wewt
?!?! What
You wanted it a sticky, I added it to the FAQ. Is there a problem?
Old 08-13-2008, 10:50 PM
Originally Posted by VIP1
?!?! What
No....Wewpty wewt is a "good job" term or " awesome".
Old 08-14-2008, 12:38 AM
VIP1's Avatar
oh. ok. misunderstood.
Old 08-14-2008, 02:07 AM
Lol no problem man Thanks for teh sticky!
Old 02-11-2009, 05:33 PM
JoeD427's Avatar
hey would this help my climate control lights from flickering on and off?
Old 03-23-2009, 10:52 PM
BLKNRDPREDATOR2001's Avatar
i tried what you said, no cracks well at least that i could see, but i noticed that when i would mess with the connector or shake the circuit board the radio would turn off, i would hear the relay clicking. what do you think might be wrong if no cracks or burns were visible. Help!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 09-15-2009, 10:24 PM
2KThunder's Avatar
Does anyone have pics of said circuit board? Its hard now that the original images have been deleted. My radio cuts off. Thanks
Old 09-15-2009, 10:37 PM
2KThunder's Avatar
Nevermind, got it from another post woot
Old 09-20-2009, 03:42 AM
BIG_T's Avatar
What post did u find the pics on? I have been looking for the pics forever!
Old 09-20-2009, 11:50 PM
I don't know what happened to the pics, but look at the board and find the grouping of solder spots that looks like a "T". I think there are like 3 pieces going horizontal and four going vertical. Get all those and your good.
You literally can't even see the cracks. The lighting and angle you look has to be like perfect.
Old 09-21-2009, 12:39 AM
02TransAm/Batmobile's Avatar
I'm not understanding, what is this for exactly?
Old 11-03-2009, 02:08 PM
F-117HWK's Avatar
Would this be a possible fix to the fact that my radio and windows randomly turn on/off and stop working? If so THANK GOD
Old 02-19-2010, 06:58 PM
Chaos07's Avatar
my trans am is starting to show signs of fault solder points...the radio goes out randomly and the windows stop workng but i needs pics of where to go n where to solder
Old 05-13-2010, 08:22 PM
Jimmy P's Avatar
My radio and dashboard lights flicker, as in they get a bit dim and then go back to normal. But the radio never completely goes off, and the windows always work. Would this still be a BCM issue?
Old 05-30-2012, 10:07 AM
dc4bill's Avatar
^^ same issue here, lights flicker especially on first start, ext. lights, interior lights all of them, and the volt gauge bounces in unison with the lights, is this the fix for it and please, somebody post the "T" solders in a pic
Quick Reply: How to fix your radio/door locks/windows etc from flickering.
