LS7 Carbon Fiber Intake Manifold
Old 08-21-2008, 09:40 PM
c5blkvette's Avatar
Default LS7 Carbon Fiber Intake Manifold
Hi guys,
Just wanted to show you what I have been working on for the last couple of years. This is a carbon fiber (7layers x 0.2mm - 3K 2x2 twill cloth from Japan) intake manifold with long runners. The runners have been through numerous iterations to maximise the flow at higher RPM while still maintaining good low-RPM torque. The plenum has also been optimised for the lowest possible volume without affecting significantly flow for good throttle response.
The CNC aluminium flanges contain a taper to the larger runners that allows the LS7 heads to be ported by about 1.5mm to take full advantage of the runners. The injectors also fire at a better angle and position compared to the standard GM. Throttle body also contains a taper to allow a standard TB to connect to the manifold. The TB can be ported to allow a free flowing 100mm diameter TB if desired.
Here in Australia, the LS7 is very scarce, but I managed to get hold of a stock engine in a Holden Commodore and we did a pure bolt on with no tuning or modifications to the other intake components. Let me say that the LS7 intake is extremely efficient and I was hoping to be at least even on a bone stock engine due to the larger runner diameters and slightly shorter length. Well, we picked up about 8HP over the stock engine and had a longer torque curve. The engine lost a little bit of power under 3000rpm, but this was to be expected.
Where this intake will shine will be above 500HP, where the stock intake starts to restrict the intake charge (and with tuning).
Jamie
Old 08-21-2008, 09:43 PM
KadinZ's Avatar
that is F'king sick.
Old 08-21-2008, 09:44 PM
firefighting1101's Avatar
PURE SEX!!!!!! that is freakin amazing, now we just need to see some numbers...from a ported ls7 to that beauty!
Old 08-21-2008, 09:45 PM
are you going to be making enough to sell at any reasonable price...like in the range of a sheet metal?
Old 08-21-2008, 09:51 PM
dadem0n's Avatar
Awesome work!!!
So which workshop is behind this?
Higgins? GMM? SQP? Russos? Sams?
Old 08-21-2008, 09:56 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Thumbs up
Beauty Man....
Old 08-21-2008, 10:03 PM
c5blkvette's Avatar
Price would be reasonable (less than most expect). The problem I will have is making them in any sort of volume. I have a day job and this is done on the side... most people dont know how much time it takes to put one of these babies together.
Old 08-21-2008, 10:10 PM
if you dont mind pm'ing me or posting a price. i have a friend looking for an alternative to his ported ls7
Old 08-21-2008, 10:26 PM
DopeFedZ's Avatar
Old 08-21-2008, 10:29 PM
Suaveat69's Avatar
Nice!!!
Old 08-21-2008, 10:32 PM
DB Z28's Avatar
Could you Email me with a price and more pictures Thanks Dale
Old 08-22-2008, 02:09 AM
Closed ex-Sponsor Account
408trans_am's Avatar
WOW that is probably the sexiest thing i have ever seen as far as car parts go. Simply stunning
Old 08-22-2008, 02:57 AM
sixt9er's Avatar
Default Daaaamn!
That is definitely a nice piece!
Now, you know i gotta ask...will you make an L92 intake like that?
Curious to know the price of the LS& one that you have.
Old 08-22-2008, 03:31 AM
c5blkvette's Avatar
LS3/L92 style is relatively easy to do. It would have the same runners and plenum and then port matched within the 1/2" of flange length (basically just different CNC flanges). I already have some flanges made up, just not a complete manifold - maybe in about a month.
The intake is very low profile (not too much higher than stock) and will fit under Corvette hoods.
...I will be offline till Sunday, so will answer further questions then.
Old 08-22-2008, 03:34 AM
c5blkvette's Avatar
My company is OZMO Engineering and I mainly do consulting and contract design and manufacturing of CNC and carbon fiber parts.
Old 08-22-2008, 09:18 AM
Haans249's Avatar
I find it really strange that you're losing low end torque with longer runners. What do you think could be the cause of this? Have you tried running a larger plenum?
Looks SICK btw
Old 08-22-2008, 09:49 AM
See5's Avatar
Wow!
That is a work of art.
Old 08-22-2008, 12:50 PM
triggerjerk's Avatar
Maybe weiand could hire you
Nice work.
Old 08-22-2008, 01:08 PM
WKMCD's Avatar
What is the runner lenght and plenum volume?
Need a test mule on the L92 manifold?
Old 08-22-2008, 01:18 PM
ssmith512's Avatar
Quick Reply: LS7 Carbon Fiber Intake Manifold
