For Sale - complete L92/LS3 crate engine - Houston
I bought four of these L92/LS3 crate engines, selling two of them. These are all-aluminum 6.2L engines, factory rated at 404 hp and 417 ft-lbs. They are complete intake to oil pan (for truck setup) and have exhaust manifolds, water pump, coil packs, fuel rails. No belt driven accessories, other than water pump.
These are the exact same shortblock and heads found on the LS3, you only need to swap the intake manifold and oil pan to the car types.
These are brand new GM crate engines, which sell for $6200 usually. click here
Price: $4500 each. Can deliver in the Houston area, they are sitting on my car trailer now.
Tony
Tony
yes, you would have to change the relutor wheel on the crank for your crank sensor to retain the ls1 pcm. then you would use your intake and accessories drives, oil pan and pick up tube, and any sensors from your stock ls1. that or get a ls2/3 harness and pcm, or a stand alone pcm/harness.
