Port/polished Throttle Bodies
[size="5"]im Selling 2 Ported And Polished Throttle Bodies, Both Have Had Ported/polished , Half Shafted,knifed Edged,screws Ground Flat, And Bump Stop Mod Done And Drilled For Screw For Perfect Adjustment To Get The Perfect 90 Degree Opening When Used A Scanner. 1 Throttle Body Is A Small Cam The Other Is A Large Cam . The Large Cam Throttle Body Has Had The Iac And Vent Hole Filled And Brass Tubes Inserted.I ACCEPT PAYPAL ONLY, THE SMALL CAM I WANT $100 PLUS SHIPPING(small cam sold) AND THE LARGE CAM $80 large cams DOESNT NOT COME WITH SENSORS, DOESNT COME WITH SENSORS
what does ur throttle body look like match up were the throttle cable goes, thats called a cam i have eather or both wowuld work but u would have to adj the cable tention.just look at your throttle body and match it with one of mine.
