rollmaster timing chain
SOLD.........................
I have a brand new rollmaster double roller timing chain. part # 11-1160
Rollmaster Double-Roller Adjustable Timing Set, Heat-Treated, LS1-Based Cars
This double-roller timing-chain set is a perfect complement to our high-performance camshafts and other LS1/LS6 engine components. It offers greatly enhanced strength and accuracy compared with the stock piece and even allows for timing adjustments (advance or retard) of up to 8 degrees. The set contains an adjustable, nine-keyway nitrated crankshaft sprocket; a double-row chain; a nitrated camshaft sprocket; two oil-pump-spacer plates; detailed instructions; and all necessary installation hardware. Compatible with all 1997-03 "Gen III" engines (LS1/LS6, 4.8L, 5.3L, 6.0L).
111160, adjustable, chain, install, instructions, ls1, ls6, oil, rollmaster, set, sets, timi9ng, timing, timingchain
