MSD LSx coil packs, SPEC Stage 2 clutch and flywheel, T56 rebuild kit, etc!
Lots of goodies here, ****** them up now before they're gone!
T56 basic overhaul kit. Includes steel 3-4 shift fork. SOLD
White 6-spd shift ball - SOLD!
5.3L heads, 862 castings, good shape - $75
Also have LS1 valves to go with them for an additional $20 if you'd like
SPEC Stage 2 clutch and steel flywheel - brand new never taken from packaging - NO LONGER FOR SALE, THANKS SPEC!
MSD Super Conductor plug wires, brand new in box - $60
NO LONGER FOR SALE, THANKS MSD!
MSD Blaster Coil packs, brand new in box, complete set - $600
3rd gen Z28 front wheels. No centercaps. Dirty, but very usable. Get them out of my way! - $75 takes them
87 TPI setup - Complete down to the 9th injector, includes TB, but no distributor cover. - $175
NO PICTURE
Barnes 6-stage dry sump oil pump - good shape, needs new pulley most likely. $200
Bug catcher for drag car, fits standard 4-bbl carb. Came off of my AMX. No need for it, it's just in my way. Needs cleaning, but works great. - $50
Stock LS1 rocker arms. Unsure of mileage, but they were lower when they came off. They came from a friend's 00 SS. $50
Stock 99+ LS1 cam. Great shape, yanked with low mileage - $40
LS2 timing chain, good shape - $20
Ported LS6 oil pump. I want to say it came from Futral, but don't hold me to that! In great shape, been on the shelf a while - $100
Stock LS1 valve springs - $20
Stock T56 shifter handle - $5
Hurst shifter rod with 1 Ball epoxied on - $5
Stock LT1 Camaro turn signals, some cracks but don't leak - $5
Stock Hurst shifter for T56 with rod and **** - $60
Stock factory shifter - $20
T56 slave cylinder, good shape - $30
Alternator for LS1 - $50
Starter for LS1 - $50
NO PICTURE
You mean the block with heads and LS1 valves?
It ain't gonna be cheap with you being across the country, I'm betting at least $200. I can get some quotes if you'd like.
Found some more parts that we had and that HRT Performance donated for us to sell.
Stock LS1 camshaft - $50
LS1 oil pan with windage tray - $100
LS6 oil pump - $100
LS2 timing chain (no sprockets) - $25
LS6 oil pump - $100
