FS: GM 85mm MAF - $65 shipped
Still has the screen. This will require MAF tuning. You can use the new 05+ tables as a reference point for this MAF. It is off of a 05 vette with 9.5k miles
- Matt
- Matt
Yes Sort Of.. well the SLP MAF has a resistor that is setup to work with a stock tune. I would recommend a quick tune when changing airflow modifications. The SLP one you would get by with for a bit without a tune, this one you need the tables completed.
If you had HPTuners I'd be glad to modify the file or send over the MAF table...
